Floor Trusses Vs Tgi - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-25-2011, 07:29 AM   #1
floor trusses vs tgi
Want to know which system is better solution for the cost. Building a large ranch style home and do not want squeaky floors.
Solowingrider is offline   Reply With Quote
Old 11-25-2011, 08:46 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
"Duck" here come the opinions.
TGI's are far better than trusses. Squeaks come from movement and trusses move readily compared to TGI's. Keep in mind all building has its recommendations. Don't exceed the recommendations.
Old 11-25-2011, 09:17 AM   #3
Rewards Points: 150
Since ranches are typically single story tgis shouldn't come into play. Trusses are cheaper than stick built and are easier to install. If I was you, I would use trusses and keep the money for 2x6 exterior walls and extra insulation.
OhioHomeDoctor is offline   Reply With Quote
Old 11-25-2011, 09:38 AM   #4
Framing Contractor
Why shouldn't I-joists come into play with a single story home?
What does that mean? Stick built what?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-25-2011, 09:42 AM   #5
Rewards Points: 150
Because dimensional lumber is much better.
Using rafters.
Old 11-25-2011, 09:47 AM   #6
Framing Contractor
So what you meant was don't use floor trusses or I-joists for the floor....use dimensional lumber for the floor joists?
Using rafters.
Why are you talking about rafters when the guy is asking about floor joists?
Joe Carola
The Following User Says Thank You to Joe Carola For This Useful Post:
woodworkbykirk (11-25-2011)
Old 11-25-2011, 09:49 AM   #7
Rewards Points: 150
Because that will be his next question Joe.
Old 11-25-2011, 09:56 AM   #8
Framing Contractor
Wow your pretty slick. Explain why dimensional lumber is better to use on a single story home compared to I-joists. Explain why it matters whether you're building a one or story story home when deciding what to use for floor joists.
Joe Carola
The Following 2 Users Say Thank You to Joe Carola For This Useful Post:
Bud Cline (11-25-2011), woodworkbykirk (11-25-2011)
Old 11-25-2011, 10:13 AM   #9
Residential Designer
AndyGump's Avatar
Rewards Points: 676
Send a message via Skype™ to AndyGump
Alright, an opinion thread.
It really depends on the whole construction, will the design include all mechanical in the basement/crawl space?
In the attic?
How big the house is?
Labor for installing whatever is to go in?
Insulation required for the location?
Etc.
Andy.
AndyGump is online now   Reply With Quote
Old 11-25-2011, 04:00 PM   #10
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,124
tji's can span greater distances than conventional lumber, the size of the joist will depend on the layout of the floor and what kind of loads it has to support. however they cannot have large holes drilled in them for plumbing
ojt's cannot span the distances that tji's can however they are made with an open web design which wires, pipes and hvac can be run through without having to drill or notch anything.
as for squeaks... ive never seen a ojt floor system have squeaks, the joints get snot glued outta them which eliminates raw wood on wood rubbing which is what causes squeaks, if the floor is framed properly, all sheathing is glued as well as the joist hangers getting a dob of glue in them before the joist is dropped in, it shouldnt be a issue
woodworkbykirk is offline   Reply With Quote
