Floor Truss Versus Ibeam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-13-2010, 03:29 PM   #1
Floor Truss versus Ibeam
I am working on a 2nd story addition and the floor joists will span 22ft. i was planning on using 16 inch tall ibeams spaced 12 inch on centers to get a stiffer floor - but now i a considering having trusses built maybe a bit taller ..18 or 20 inches and get them from the same supplier as my roof trusses...they will be a little less expensive than the ibeam (ibeams are wood)
Any practical advice on which to use..engineering wise they are equivalent (or can be when spaced right)
remodelingdan is offline   Reply With Quote
Old 05-13-2010, 03:34 PM   #2
i like the framed floor truss. you need to pay attention to any mechanicals youre running
The older I get the better I was
Old 05-13-2010, 03:53 PM   #3
Since you want stiffness you need to compare the dead + live load rating of each for a given deflection; L/360, L/240, whatever. For a 22' span, L/360 is a 22(12)/360 = 0.7" midspan sag.
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 07:38 PM
tile shower versus shower insert yakgirl Carpentry 12 11-03-2008 02:26 PM
Ductless versus Central Air Upgrade ??? wrldruler HVAC 9 09-25-2008 01:05 PM
Double Handle versus Single Handle kitchen faucet Lindahoney Plumbing 7 11-20-2007 09:36 AM
Metal versus Traditional Shingle Roof 4powells Building & Construction 2 04-28-2005 09:40 AM
