Old 12-18-2012, 04:38 PM   #1
Floor truss alteration.
I'd like to lower the shower area by 2" to enable me to go curb less on the enclosure. If I remove the top plate of the floor truss and sandwich the remainder between 5/8" plywood staggered will I be ok structurally?
Jigwood is offline   Reply With Quote
Old 12-18-2012, 04:59 PM   #2
"Nail-Bender"
Welcome to "DIY"!
The standard instructions concerning engineered, structural components -
(A floor truss would be in that category)
No alterations: unless signed off by an engineer.
I don't think you should do that!
Wait and see if you get some other responses.
rossfingal
rossfingal is offline   Reply With Quote
Old 12-18-2012, 06:09 PM   #3
Master General ReEngineer
Bondo's Avatar
Ayuh,.... With a gap in the top plate, ya don't have a truss anymore...
The Following User Says Thank You to Bondo For This Useful Post:
woodworkbykirk (12-18-2012)
Old 12-18-2012, 08:32 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
no you can not. any alterations to a truss must be okay'd by the engineer who designed it. or have them design the modification required
the correct thing to do is to build up the surrounding floor in the room then create a slope to the drain with concrete,. it only has to be minimal
woodworkbykirk is offline   Reply With Quote
Old 12-18-2012, 09:12 PM   #5
GBrackins's Avatar
Jigwood,
Welcome to the Forum! Don't think I need to repeat what has been said already ..... perfect advise
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 12-19-2012, 04:12 PM   #6
in some instances you can use conventioinal lumber that matches the dimension of the engineered joists.. you can notch them where the shower will be but they have to be doubled to maintain their strength.. check with an engineer first though
heat duct alteration castillo HVAC 0 10-31-2011 10:02 AM
