Floor Replacement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-04-2010, 01:28 PM   #1
Floor replacement
We are getting differenct opinions on how to reconstruct a floor in our church. If we put two layers of flooring (sub floor and then flooring) directloy over the subfloor do we want a moisture barrier between the two. Half the contractors want to do a moisture barrier and the other half say it will rout the subfloor and begin to smell musty. This is, of course a wood floor over a crawl space.
graham johnson is offline   Reply With Quote
Old 09-04-2010, 07:48 PM   #2
Registered User
Rewards Points: 5,204
No vapor barrier: http://www.buildingscience.com/docum...n-crawlspaces/
http://bct.nrc.umass.edu/index.php/p...ient-flooring/
Gary
