Floor Load Limit - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-31-2013, 10:38 PM   #1
Floor Load Limit
I need to bring 1209 square feet of hardwood flooring to acclimate before installation. The total weight of the flooring is approximately 3200 lbs. I am planning on spreading this out around an 11' x 13' room.
By my calculations, that is about 22 lbs per square foot. I have read that the standard 1st floor live floor load is 40 lbs per square foot.
The floor joists are 2 x 10 and 16" off center, with a 13' span.
Will this be alright?
fishyjoe is offline   Reply With Quote
Old 02-01-2013, 12:29 AM   #2
GBrackins's Avatar
Rewards Points: 2,108
are you planning on having a walking area to get around in the room or just start stacking at the farthest corner and work your way out? A pathway would reduce your storage square footage and increase you square foot load.
2x10 #2 spruce-pine-fir joists spaced at 16" o.c. with a span of 13' should be good for about 70 pounds per square foot total uniform load (live + dead load) and still meet the L/360 deflection limit.
Hope this helps.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Lennox Furnace - Primary or Secondary Limit Switch Open georgemeaders HVAC 4 12-12-2012 08:21 PM
Trane limit switch mikethe ductman HVAC 7 01-18-2012 11:46 PM
Blower fan won't turn off - limit switch replaced Laplacian HVAC 4 02-14-2011 12:55 PM
Furnace limit switch Deereman HVAC 1 12-11-2010 11:56 AM
AMER STD open high limit sei564 HVAC 6 03-16-2010 09:22 PM
