Old 03-02-2011, 01:30 PM   #1
floor joists
maximum hole size for electrical cable. Can holes be made with a drill and jig saw? Wood is too hard for hole saw. 100 yrs old.
Taters Grandpa is offline   Reply With Quote
Old 03-02-2011, 07:02 PM   #2
floor joists
The size of the hole depends on the size of the beam. How big of a hole do you need for a wire? You can drill a 1" hole in the middle of a 2x6.
Most holes in wood, would be done with a drill. Forget the jigsaw.
Ron
Old 03-02-2011, 10:23 PM   #3
Moderator
floor joists
Wow, a centurion!
http://arch.umd.edu/Tech/Structural_..._Guide_A11.pdf
Gary
Clothes taking longer to dry?
The Following User Says Thank You to Gary in WA For This Useful Post:
boman47k (03-03-2011)
Old 03-03-2011, 12:36 AM   #4
floor joists
How big is this cable? Hole in the middle of the floor joist closer to the centre of the span would be the best choice.
can you do it ith a 1" auger or less?
masterofall is offline   Reply With Quote
Old 03-03-2011, 09:21 AM   #5
floor joists
I thought most codes stipulate no more than 1/3 of the size of the joist. That may be intended for other framing members.
I'm like the others, what size wire/cable?
If worried about the size of the hole, why not use insulated staples. Is the wood too hard for them? second story?
Ditto on forgetting the jigsaw.
Old 03-03-2011, 03:17 PM   #6
floor joists
Forstner bit.
pyper is offline   Reply With Quote
