Old 03-24-2012, 11:45 PM   #1
floor joist repair the proper way
Hi,
I have a floor joist that has gotten some water damage and the joist needs to be fixed. We had thoughts on going back to "good wood" and making a slice to the end but not sure how to do it should we do a board on each side of the existing joist? Or is there a a metal clamp like thing such as what you would put to hang trusses. is there something like that or should we kill it with screws?
jmay is offline   Reply With Quote
Old 03-24-2012, 11:58 PM   #2
Go back and look at your post, makes little since to me.
A picture would sure have been helpful.
Most often it's best to sister a full length new joist using constrution adhesive and carrage bolts.
Just a patch will do little good.
Has the problum been corrected that caused it to rot?
Old 03-25-2012, 08:09 AM   #3
MarginallyQualified
Originally Posted by jmay View Post
...the joist needs to be fixed.
...going back to good wood and making a splice...
...a board on each side of the existing joist?
...metal clamp like thing such as what you would put to hang trusses
New wood on one side or the other should be plenty.
If you have access to some sheet steel... then sandwich a piece between.
Pay special attention that the new joist is well supported at the end.
Nail it thoroughly and a couple of carriage bolts won't hurt either.
hth
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Stone Foundation 'Temporary' Repair... Peter B. Building & Construction 17 12-16-2010 01:27 PM
Drywall repair Transmico Building & Construction 2 11-24-2010 07:17 AM
sill plate repair and joist repair sandra barrier Building & Construction 3 10-09-2010 12:05 PM
Proper way to repair oversized outlet hole in drywall Plasmech Painting 16 06-24-2010 12:09 PM
