Floor Joist Repair - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-13-2012, 08:49 AM   #1
floor joist repair
My existing home has 2 x 8 floor joists. When the previous owner finished the basement, he cut 1" out of the bottom of the floor joists so that he could push the 1/2' copper piping flush mount. From there he drywalled the basement ceiling. I wish to repair this structural defect. How do I do it? M
jeffrolph is offline   Reply With Quote
Old 08-13-2012, 09:29 AM   #2
AHH, SPANS!!!
Rewards Points: 1,166
How long of a span are the 2x8 floor joists? Thanks
hand drive is offline   Reply With Quote
Old 08-13-2012, 09:56 AM   #3
span
12 feet
Old 08-13-2012, 10:13 AM   #4
Rewards Points: 660
Where in the 12 ft span did he do this? Was it near the walls or near the center? Are there cracks above the notch out like the joist is starting to sag? Was only 1/2" notched out or more?
More than likely a 1/2" notch on an 8" joist should not cause any problem. I will let more expert advise than mine confirm this.
B
Beepster is offline   Reply With Quote
Old 08-13-2012, 10:20 AM   #5
The notches are centre span and are 1/2"-1 inch. I havent noticed any cracking, etc in the joists. I dont think the joists are at risk of failure however I wish to correct this problem as someday if I wish to sell the home, it could be a deterent.
Old 08-13-2012, 10:32 AM   #6
Rewards Points: 256
I'm more curious why you ripped out the drywalled ceiling? Are there bigger issues to be dealt with? What are you replacing it with? If going to a drop ceiling just drop the pipe down below the joists and sister a full 2x8 to it. Under it or through it are your options.
moneymgmt is offline   Reply With Quote
Old 08-13-2012, 10:33 AM   #7
Rewards Points: 12,886
? How did you find out it was done if there was drywall installed over it?
In order to fix it the floor above or the ceiling below would have to come out, a whole lot of work and little to gain.
If the floors not saging an the drywalls not cracking, forget about it.
Old 08-13-2012, 10:39 AM   #8
The kitchen drain pipes were clogging so I wanted to access the drain pipe therefore removed the drywall. My plan was all along to pull the existing drywall ceiling out and install a drop ceiling so that there is easy access to plumbing, electrical, hvac ductwork, etc. That's when I found this issue.
Old 08-13-2012, 10:40 AM   #9
The drain pipe has been replaced. This issue had nothing to do with the notched joists.
Old 08-13-2012, 10:59 AM   #10
If you can spare the head room the fastest cheapest way would be to just install some 2 X 4's laying flat againt the floor joist, if you put some constrution adhesive on the joist first then use at least 3" ceramic coated decking screws you have in effect made an I beam.
Old 08-13-2012, 11:17 AM   #11
Rewards Points: 502
Some figures;
assuming the following; span = 12ft; joist spacing = 16"; code live load 40lbs/sq ft; dead load 10lbs/sq ft
and assuming there is only floor above (ie no partition or suchlike)
then each joist will be supporting approx. 800lbs.
If the notches are near mid span, then the joists will for practical purposes be 2x7s.
Under this load, the bending stress will be something over 1100lbs/sq in.
Most structural timbers can go up to 1200lbs/sq in bending stress, and some codes allow a small increase for load-sharing between the joists
From a structural point of view, IMO his floor is ok, but as he says, a problem may arise if he comes to sell. Some clueless surveyor may point this out to the buyer and set alarms bells ringing unnecessarily. Best thing might be to arrange his new ceiling so the notches can't be easily seen.
tony.g is offline   Reply With Quote
Tags
structural damage
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 07:42 AM
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 01:42 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
Repair Compounds saggdevil Painting 3 04-25-2010 04:02 PM
