Floor Joist Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-09-2009, 06:47 PM   #1
floor joist question
hi,
in my 10X12 shed with "loft," i was originally going to frame the room parallel to the 10' run, but changed it to span the 12' run.
i'm wondering, for the loft floor joists, do they now need to be 12'ers to run parallel to the rafters, or can the be 10s and run the other way, then just tie in the floor with blocking to the walls carrying the rafters?
i was hoping to get away with X6 or X8 on the 10' run, as it's just for a kid's clubhouse and future storage, not actually a full-out living space.
i'm suire all of you will tell me to do it to code and use X10s?
thanks.
wombosi is offline   Reply With Quote
Old 04-09-2009, 06:54 PM   #2
Rewards Points: 150
I used this calculator for my deck:
http://www.decks.com/Calculators/JoistSpan.aspx
it says, @ 16o.c.
2x6 - 9'9" max span
2x8 - 12'10" max span
2x10 - 16'1" max span
johnnyboy is offline   Reply With Quote
Old 04-09-2009, 06:57 PM   #3
it says, @ 16o.c.
2x6 - 9'9" max span
thanks, my wall framing is at 2'OC. can i do 2X8 spanning 12' 2'oc? or should i set it up to do 16oc? 2'oc with 3/4" plywood enough?
thanks.
Old 04-10-2009, 12:45 AM   #4
Registered User
Rewards Points: 5,236
2x8 - IRC- 24"= 10'3"
2x8- UBC- 24"= 11'3" 2003 code book
That's doug/fir #2. That's 40# live load and 10# dead load PER SQUARE FOOT. That will hold..... you do the math.
Be safe, GBR
Old 04-10-2009, 09:48 AM   #5
what is IRC and UBC?
so, a 2X8 fir (not spruce?) will span 12' just fine for the purposes of a 12 year old kid and a hammock, and future storage?
thanks.
Old 04-10-2009, 12:37 PM   #6
Structural Engineer
thanks.
International Residential Code (IRC)
Uniform Building Code (UBC)
wildcat is offline   Reply With Quote
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 10:10 AM
New service Question Onytay Electrical 1 10-24-2007 06:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
