Floor Joist/main Beam Replace - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-19-2010, 09:53 AM   #1
floor joist/main beam replace
I have a 24x32 2 bedroom house. There has been water seepage into one corner of my basement for some 15-20 years (i'd guess) due to poor drainage on the backside of the house. In turn this has caused 6 of my floor joists to start rotting and the main carrying beam on one end to rot. The moisture damage is only in one corner of the house. The floor joists are 12 footers on each side of the beam BUT half the house, the floor is recessed so the 2x9 joists are sitting on top of each other with the rotten joist side on top of the other side joists. They are boxed in too which for the rotten side (maybe because they are sandwiched with the weight of the house on top??) makes things a lot! more complicated Im not no carpenter by any means but i DO have common sense and the ability to do things myself, and im confident enough to tackle it. Any advice on this would be greatly apprecited. Thanks Graham
PS- I just bought the house in december of 09.
grahamsurette is offline   Reply With Quote
Old 04-19-2010, 10:19 AM   #2
Post photos and diagrams.
Old 04-19-2010, 10:20 AM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Graham, Welcome to the Forum.
Jacking up a house to replace rotting beams is a major operation that requires a permit. Think safety, You don't want to be under the house cranking on a wimpy Screw Jack when the whole thing comes crashing down.
My advice would be first to get some professional advice. You don't want a speaker at your Memorial service to say that Graham thought he got good how-to advice off the internet.
Disclaimer
& Stay Safe
.....Bob Lavery
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 01:07 PM
Replace Main Beam in different location? jrdamien Carpentry 5 01-10-2009 01:13 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 04:24 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 08:46 PM
