Floor Joist Insulation Support - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-23-2011, 10:27 PM   #1
Rewards Points: 197
Floor joist insulation support
I have been considering for quite a while on what to use to go under my floor joists to support the insulation and seal it off from rodents and insects, yet not be a vapor barrier or retain water if there are any water leaks from plumbing.
The house rests on (36) 6"x6"x32" red heart cedar posts which in turn rest on 10" dia. x 3" high concrete piers. The posts are crossed braced both ways and the crawl space will remain open, hence the need to insulate between the floor joists. The joists are 2"x8" and the insulation will be batts of Roxul.
Well, I was able to get a good buy on 7/16" osb for less than $5/sheet. (The cheapest price I could find for 1/4" hardware cloth was twice the price of the osb per square foot, and that was just for 24 ga.)
So, not wanting to install the osb sheets tightly together so as to create a vapor barrier, my current plan is to:
Install the osb leaving about a 1/2" gap between the rows of sheets and then staple 3" wide strips of screen and hardware cloth over the gaps.
By doing this, I hope to not only prevent insect and rodent intrusion, but also to prevent a vapor barrier, yet minimize air movement through the insulation from the wind blowing under the house.
Any comments or suggestions on this method or on perhaps a better way to utilize the osb for this purpose will be much appreciated.
Thanks,
Arky
Arky217 is offline   Reply With Quote
Old 05-24-2011, 05:13 PM   #2
Rewards Points: 1,092
see my answer on the GBA forum.
Old 05-24-2011, 05:48 PM   #3
Rewards Points: 197
A reader suggested that I might use steel instead of osb for the underside of the floor joists.
That got me to thinking that I do have quite a number of 26" x 8' and 10' corrugated metal roofing panels that I had used to cover my sawn lumber while it dried.
Perhaps that would be a viable solution. It certainly would be rodent proof. And cheap, seeing as how I already have most of the panels that I would need. But I wonder if maybe, being metal, I might get some condensation on the insulation side when the steel gets cold.
Maybe drill some small holes in the metal, not sure ?
How about using the steel roofing panels; any comments ?
Thanks,
Arky
Loose fill asbestos insulation, Vermiculite GeauxCajuns82 Building & Construction 2 03-07-2011 06:59 PM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
moving a support wall 6 ft over.? help jstamps Building & Construction 1 04-20-2010 06:48 AM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 09:14 PM
Has anyone used Green Fiber blown in insulation? pomelo Building & Construction 7 02-10-2010 08:17 AM
