Floor Joist Hanging Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-17-2013, 11:27 PM   #1
Floor joist hanging question
Hi all,
I have an interesting situation where I'm trying to build/extend a floor in order to make one floor level with another. There is about a 20" height difference currently. This is in an attic. So the new floor joists will attach on one side on a gigantic glulam beam. The other end of the floor joists will rest on top of knee walls built on top of load bearing/exterior walls. The knee walls will only be about 12" tall.
My question is can my joists just rest on the knee wall, and be nailed in and blocked appropriately, or do I still need to have a header board on the end of the joists (along with blocking, etc)
I drew a picture:
chamino is offline   Reply With Quote
Old 06-17-2013, 11:32 PM   #2
Rewards Points: 13,282
Post a picture of what you really have not just drawing.
Old 06-18-2013, 07:19 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
A header will be an easier and cleaner installation and doesn't take any more material.
Old 06-18-2013, 09:02 AM   #4
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,622
Plus you still have 2" bearing, and a lot more fastening with the rimboard/header.
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
CarpenterSFO (06-18-2013)
Old 06-18-2013, 09:21 AM   #5
Pro
Rewards Points: 91
Either one would be functionally OK. Most carpenters, given the choice, would do the rim joist - it's easier to end nail a bunch of joists than to put in the blocking. Don't forget to sheath or otherwise brace that little knee wall.
CarpenterSFO is offline   Reply With Quote
The Following User Says Thank You to CarpenterSFO For This Useful Post:
MTN REMODEL LLC (06-18-2013)
Old 06-18-2013, 10:31 AM   #6
Roofmaster
Rewards Points: 2,172
Why dont you get full bearing, and block between the joists? I am somewhat concerned about having a short wall attached to the top of a bearing wall without knowing what kind of lateral forces are on that wall. Can you elaborate?
Old 06-18-2013, 11:05 AM   #7
Pro
Rewards Points: 91
Well, it's a good question, and having answered the question about how to put joists over to that edge - what are you planning to do up in that attic? I supposed that you were putting some storage up there, for bicycles, holiday decorations, etc. If you're planning to add an additional floor of habitable space, you need to get some engineering done and get some real plans, permits, etc.
Old 06-18-2013, 12:20 PM   #8
Roofmaster
Very good points. That glulam might have been designed to handle a 20 psf storage load in the attic, which is usual, and not designed for a 40 psf load which is usual for a continually occupied floor. It may be adequate, but you need a structural engineer to tell you it is.
Also how about telling us what that beam is supporting now, instead of just showing a beam in mid-air.
The Following User Says Thank You to jagans For This Useful Post:
Venting over the range convection oven question johncle6023 HVAC 4 08-31-2012 09:30 PM
Generator connection Question - Final Plan Apollo67 Electrical 24 01-30-2012 08:44 PM
LP / NG - Unusual Question... Peter B. Appliances 8 04-09-2011 09:59 AM
Adding Mudroom in exisiting garage - Foundation question screamon demon Building & Construction 2 02-02-2011 01:30 PM
hanging sheetrock/drywall question eis61374 General DIY Discussions 9 10-29-2008 11:14 AM
