-   -   Floor Joist and bathroom venting (http://www.diychatroom.com/f19/floor-joist-bathroom-venting-151368/)
bates 07-24-2012 01:28 PM
So I want to install a bathroom fan in my already finished basement bathroom. The only thing is that the floor joists are running perpendicular to the shortest route (about 4' of run). Meaning I'll have to drill 4-1/8" diamater through my 2x8 floor joists.
Coincidentally, the upstairs bathroom is directly above my downstairs bathrrom as well.
Would there be any problem drilling this size hole in about 4-5' worth of floor joists?
tony.g 07-24-2012 01:41 PM
[quote=bates;973155
Would there be any problem drilling this size hole in about 4-5' worth of floor joists?[/quote]
There certainly would be a problem. On an 8" deep joist, 2 1/2" is about the most you should do.
bates 07-24-2012 01:43 PM
How am I to route the vent then?
tony.g 07-24-2012 02:33 PM
That's your problem; you asked if it would be OK to drill a 4" + hole through an 8" deep joist.
You have to work another way round for the ducting. Sorry, but you cannot compromise the structure for ease of getting a duct through.
sixeightten 07-24-2012 02:53 PM
If that is only a half bath, you may have more options for venting the fan.
tony.g 07-24-2012 03:23 PM
If it's a short run to the outside, will your Code let you use a smaller duct, (say 2") or has it got to be 4"?
Beepster 07-24-2012 04:26 PM
Draw us a picture. Why can't you go the longer route that is parallel/in between the joists?
B
bates 07-24-2012 04:40 PM
1 Attachment(s)
laugh if you'd like at my quick drawing. At work where I don't draw so I had to be quick. Anyways, oddly enough the joist run the same direction as the lines on the paper.
Top picture is an overview layout of the master bed/bath
Bottom picture shows the change in ceiling height between the bathroom and bedroom (same height) compared to inside the closet height.
tony.g 07-24-2012 04:49 PM
Can you get hold of flat, rectangular ducting of the equivalent cross-sectional area? Something like 2" deep by 8" across would do.
bates 07-24-2012 04:55 PM
I'd have to give a look around, sounds like it's not an everyday home depot item?
tony.g 07-24-2012 05:12 PM
Have a look at this, particularly diagram 3 on p2, showing the flat ducting (it looks to be 4" x approx 2"). There are adaptors from round to rectangular.
(its a UK firm, but your hd or lowes will have something similar; if the pic. doesn't come through, I can scan it and upload).
http://www.wickes.co.uk/content/ebiz...ges/gil/93.pdf
Jim F 07-24-2012 05:22 PM
I found the round to rectangular ductwork at one of those stores HD or Lowes. Please don't bore 4 inch holes in 8 inch joists.You will probably sell that house someday and whomever buys it will inherit that mess and curse you in effigy when they discover it.
Evstarr 07-24-2012 07:30 PM
Assuming the upstairs tub doesn't come down on top of you first. ...
tony.g 07-25-2012 02:05 AM
If its any help to get some extra clearance, you can notch the underside of the floor joists to get the ducting a bit higher up. This is allowable if the notch is not too far in from the ends of the joists, and not too deep.
See this;
http://arch.umd.edu/Tech/Structural_..._Guide_A11.pdf
Most Codes have prescriptive rules for this - check yours. If you decide to notch them, don't go mad with it - you have a bathroom upstairs as well.
woody4249 07-25-2012 09:58 AM
Is the basement totally below ground level?
Is the bathroom on an outside wall?
