Floor Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-21-2007, 05:04 PM   #1
Floor Joist
I'm building a storage building and have saved up several 2x4s (pressure treated). I was wondering if rather than using 2x6's for the joists, could I use 2 2x4s either nailed together or even glued together making a 4x4?
Would this be wise or is it not normally done because of the normally added cost?
Thanks,
Terry
mtnfloors is offline   Reply With Quote
Old 03-21-2007, 05:43 PM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Thanks,
Terry
You will not get the same results... Even if you bolted them together, there will be sagging....That is why you never see it done...
- Build Well -
Old 03-21-2007, 07:28 PM   #3
General Contractor
joasis's Avatar
What is the distance you are spanning?
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 03-21-2007, 07:38 PM   #4
The building itself is going to be something like 10' x 10'. As far as the span of the joist, it would not matter to me, if i could use the 2x4's but I want the building to be sturdy.
Old 03-21-2007, 07:54 PM   #5
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Don't do it (for floor joists anyway)
Brik is offline   Reply With Quote
Old 03-21-2007, 08:39 PM   #6
Thanks, that's what I thought. I just had them and didn't want to spend more money if I didn't have to.
I will stick with 2x6 on 16" would 24" be ok for a storage building?
Old 03-21-2007, 10:23 PM   #7
Darylh's Avatar
I never space more than 16 o/c regardless of what the building is used for. You only save 2 joists on 10 feet.
Darylh is offline   Reply With Quote
Old 03-22-2007, 04:21 AM   #8
I'd also suggest that you keep them 16" O.C...
I have a garden shed that's about 8'x10'.
I have alot in that little shed, including a snow blower, lawn mower, bags of fetilizer, blowers, vacs, tools, gas cans, propane cans. etc....it adds up ........... and the weight adds up too....
- Build Well -
Old 03-22-2007, 07:39 PM   #9
Thanks, I didn't even think that it was only 2 more. Thanks all for the help,
Old 03-22-2007, 07:53 PM   #10
Missed that on your post...good point to bring out....
- Build Well -
Old 03-22-2007, 10:10 PM   #11
Darylh's Avatar
I have my moments
