Floor Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 04:32 PM   #1
floor joist
I want to remove a beam in the basement as I think that it is not necessary and the steel jack posts are in the way. These are not cemented in the floor and appear to have been added later. The room above is a family room with no significant load. Floor joist are 2x8 16" on center and span 12 feet. I am not sure why the home builder or someone later added a beam about 4 feet out from the wall with two jack posts spaced at 7 feet in a 20 foot room. They also tried to double up the floor joists by strapping 2x6ls along the side of the the floor joists. There are no structural walls above on the first floor that would require this beam.
dougshackles is offline   Reply With Quote
Old 02-04-2012, 04:40 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,326
the beam is carrying your floor system.. dont mess around with this unless you consult a engineer first.. if you dont know what your doing dont touch this
woodworkbykirk is offline   Reply With Quote
Old 02-04-2012, 04:51 PM   #3
floor beam
It was added after the fact. 2x8's are supposed to support the load on a 12 foot span, why would anyone add a beam??
Old 02-04-2012, 05:53 PM   #4
Civil Engineer
Rewards Points: 4,938
I am not sure what your question is. You seem to be convinced that the beam was added after the fact, and you seem equally convinced that it is not necessary. If you are asking an internet chat forum to offer a structural opinion on the necessity of your beam, I believe you have come to the wrong place. Either you make the call, and accept responsibility if it turns out the beam is needed, or you hire an engineer or architect to perform an investigation and tell you what they think.
Old 02-04-2012, 06:02 PM   #5
Framing Contractor
You already have your mind made up that the beam means nothing. What's you point? No one here can agree with you. There has to be some reason it was put there. It wasn't just put there for show. Hire an architect or engineer to come look at it. Impossible for someone here to yell you its not needed it what its there for.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 02-04-2012, 06:08 PM   #6
Thanks guys, it just doesn't make any sense to me knowing the span for floor joists and all, maybe one of the previous owners found a little bounce in the floor above.
Old 02-04-2012, 06:15 PM   #7
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
Perhaps you have tile on the floor upstairs and they wanted to stiffen the floor for the tile?
Maybe the lumber used in this scenario was, for some reason, defective or not labeled or the wrong species and the inspector wanted to see new labeled lumber there?
The joist span for a dead load of 10 lbs. and a live load of 40lbs. works (barely) with a deflection of L/360.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
dougshackles (02-04-2012)
