Floor "HUMP" At Kitchen Entrance..... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-25-2008, 12:52 AM   #1
fastback4's Avatar
Rewards Points: 51
Floor "HUMP" at kitchen entrance.....
Newbe at DIY. Searched all the threads & posts about Main support beams & sagging floors, but i have a "HUMP" at my kitchen entrance (about 12" circumfrence). I bought the 60'x30' 1977 single level ranch (crawl space) in May, 2007 and the "Hump" appeared March 2008. It's a solid hump (not saggy or bouncy). My floors have insulation installed with wire holding it up. I can remove the insulation if i can get a suggestion what to look for. I can provide pictures if it's needed...Thanks in advance.........Tom
fastback4 is offline   Reply With Quote
Old 04-25-2008, 07:16 AM   #2
RippySkippy's Avatar
Pictures of the hump area from below would be good. Remove the insulation and expose the sub-floor, and joist. Until we can help you see what to look for, it's much like the blind leading the blind.
RippySkippy is offline   Reply With Quote
Old 04-25-2008, 10:40 AM   #3
fastback4's Avatar
Rewards Points: 51
Will have a picture tomorrow...Tom
Old 04-27-2008, 09:07 AM   #4
Probably a girder that runs along the wall or someone added a pier to "fix" a sag or dip and now you have reverse curvature or uneven settlement on either side of the pier. Pictures of the crawl would help
ncgrogan is offline   Reply With Quote
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 08:31 PM
sagging kitchen off back of house DanBress Building & Construction 12 03-03-2008 09:20 PM
Bath entrance inside kitchen area rich121 General DIY Discussions 1 12-16-2007 05:44 PM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 10:23 PM
