Floor Gonna Cave In??? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-19-2013, 07:03 PM   #1
Rewards Points: 878
Floor gonna cave in???
We tore down sheet rocj and put up new in our garage( turning into a den) and now when we walk in certain places above it there is a creak and not a floor kind of creak but more like it's a beam loose or the something is weak? How can I check this out further? Should I try to record the sound? Thanks very much,
Mstrlucky74 is offline   Reply With Quote
Old 12-19-2013, 07:10 PM   #2
DIY staff
Rewards Points: 7,174
For the best answers--post a picture of the outside of your house--so weunderstand the structure.
Also a picture of the floor/cieling when it was open,if you took one.
Simply demoing the old drywall and adding new should not have affected the house framing---Did you chance any framing or supports?
Old 12-19-2013, 07:20 PM   #3
Rewards Points: 878
Originally Posted by oh'mike
For the best answers--post a picture of the outside of your house--so weunderstand the structure. Also a picture of the floor/cieling when it was open,if you took one. Simply demoing the old drywall and adding new should not have affected the house framing---Did you chance any framing or supports?
We did have a carpenter remove a door into the pace and make a 5' opening but there are headers and a steel support pole( forgot name ) there... And this was about 3 months ago and it just started. I will take pics... Thanks a lot
Old 12-20-2013, 06:31 AM   #4
DIY staff
There are so many things that cause structural noises---most are just irritating--some are really scary---give us something to chew on----
Old 12-20-2013, 07:56 AM   #5
cortell's Avatar
Rewards Points: 504
Sounds like you might be a fan of the NPR show Car Talk.
cortell is offline   Reply With Quote
Old 12-20-2013, 08:27 AM   #6
Rewards Points: 878
I actually am!
The Following 2 Users Say Thank You to Mstrlucky74 For This Useful Post:
cortell (12-20-2013), oh'mike (12-20-2013)
Old 12-20-2013, 01:20 PM   #7
Mold!! Let's kill it!
Rewards Points: 2,012
Changes in humidity levels due to colder temperatures allow framing members to dry and shrink slightly. A piece of blocking or something that is not nailed completely tight may be rubbing. Sometimes they can sound terrible. Sometimes even rearranging furniture in a room can cause things to screech. I've even seen subflooring that wasn't glued down bow slightly and then squeak against the nails. Walk around and try to isolate the noise to a particular spot, then see if you can figure out how to secure it. It's probably not a serious structural issue.
The Following 2 Users Say Thank You to Maintenance 6 For This Useful Post:
oh'mike (12-20-2013), Windows on Wash (12-20-2013)
Old 12-21-2013, 10:41 PM   #8
K&B Designer
Live_Oak's Avatar
That would be the first thing to see if you have pictures of when the walls were open. If the garage didn't make noises before that structural change was made, then it would be high on the list of suspects.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
Old 12-22-2013, 09:01 AM   #9
Rewards Points: 878
We here the sound above this one particular piece of ceiling Sheetrock I put up. I'm going to take it down today and look in the ceiling. Maybe something is loose etc. this sound started many weeks after the carpenter made the doorway opening so I don't think it is that.
Thanks for all the help.
Will my floor cave in? D-O'Brien Building & Construction 8 01-29-2013 06:15 PM
Ducting questions for Ventilation System in Man Cave kctimmay HVAC 10 01-21-2013 02:49 PM
Save the Man Cave! Sidewalker Building & Construction 0 08-15-2010 11:28 AM
My new house looks like a dark cave! How many Coats of stain? bosspaige Painting 3 05-13-2010 07:45 PM
Girl Cave Plans: AC Vent question downrightart General DIY Discussions 8 04-03-2010 04:25 PM
