Floor Framing Directly On Existing Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-05-2014, 08:51 AM   #1
Floor framing directly on existing slab
Planning to build a deer shack on an existing 16' x 20' concrete slab. The slab is at least 4" thick and hasn't cracked for the 40 years it's been there. There was a small shack there that rotted out due to failed roof.
I want to build a wood framed floor over the slab for insulation purposes and comfort. Since I presume there isn't a moisture barrier below the slab, I'm thinking of build up as follows:
1) poly over slab for moisture
2) 2 x 10 pressure treated joists 16" OC
3) batt insulation
4) another layer of poly ??? Or is this not really needed?
5) 3/4" T & G plywood
Any thoughts would be appreciated.
Thanks!
papas88 is offline   Reply With Quote
Old 04-05-2014, 11:14 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,602
Ayuh,.... I like it, Except,...
#2,... I donno's ya need 2x10s,... 4s, 6s, or 8s,...
Sittin' "On" concrete, there's nothin' to span,...
#3, I'd go with styrene foam over fiberglass,...
abit more "Critter"- proof,...
'n skip #4,...
Bondo is online now   Reply With Quote
Old 04-05-2014, 11:49 AM   #3
Rob
Robpo's Avatar
Rewards Points: 826
'n skip #4,...
I have to agree almost completely with Bondo. I would have said "instead of fiberglass", over, "over fiberglasss".
Ambiguity Police
Robpo is offline   Reply With Quote
Old 04-06-2014, 11:29 AM   #4
Thanks for the replies.
I should have been clearer on my use of 2 x 10s. I plan on two bump-outs and will have a 4' x 16' on one side and a 4' x 12' on another. Also plan on using PT plywood on the bottom of bump-outs to keep out critters. Should end up with a fairly critter proof floor.
Old 04-06-2014, 12:40 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
Instead of poly over the slab, I would use "ice & water shield" (as in roofing). That way it will be self healing for any fasteners thru the slab.
Any plumbing in the floor?
Coastal South Carolina
Old 04-07-2014, 06:21 AM   #6
Thanks rjniles.
No plumbing in the floor.
Old 04-07-2014, 09:27 AM   #7
Rewards Points: 626
I would not worry about putting any thing on the slab now. Vapor barrier is to be under it not on top of it. go with rock wool insulation 100% better then foam board don't need any poly over the insulation. your good to go. I would use pressure treated for the bottom plates that way you won't rot out there.
Nailbags is offline   Reply With Quote
Old 04-10-2014, 02:53 PM   #8
Registered User
Rewards Points: 526
Poly (or epoxy coating, drainage mat;http://www.buildingscience.com/docum...ms?full_view=1) on the slab is acceptable though will do nothing for the the thermal bridging of the joists/ply from the slab/earth temperature there- same as outside temps. Foamboard will address the thermal bridging and add cavity insulation of your choice- FG is the cheapest/worse, makes a dandy furnace filter though... rock wool will lose R-value when wet, same as FG, though I'd use it 10/1 over FG any day; http://www.google.com/url?sa=t&sourc...W6TAjQ&cad=rja
Think thermos bottle- FB on the slab (outside insulation) and the framing/cavity insulation (liquid in thermos) is warm due to room temps; http://www2.dupont.com/Tyvek_Weather...20Bulletin.pdf
Gary
Old 04-11-2014, 02:25 PM   #9
TheOldPro's Avatar
Bondo has it right -
'n skip #4,...
TheOldPro is offline   Reply With Quote
Old 04-11-2014, 04:34 PM   #10
Rob
Robpo's Avatar
Rewards Points: 826
If you are going to pour concrete under the bumpouts I would lay 2bys on flat and put 1 1/2" foam between them and then 1" foam on top of that and then plywood. That should keep your feet warm.
Old 04-12-2014, 11:38 AM   #11
Rewards Points: 626
Gary
Gary Mineral wool or rock wool is hydrophobic meaning it repels water. water and rock wool don't mix. it won't absorb water like two other forms of insulation does.
Old 04-12-2014, 05:43 PM   #12
Rewards Points: 476
Rock wool absorbs water, but at a much lower rate than fiberglass..and dries quicker when direct water source is removed. Ron
ront02769 is offline   Reply With Quote
Old 04-14-2014, 09:21 PM   #13
Registered User
Rewards Points: 526
I should have said, "not as much", thanks guys; http://www.google.com/url?sa=t&sourc...W6TAjQ&cad=rja
Gary
Room addition on existing cement slab and roof Cossack Building & Construction 6 06-20-2012 09:39 PM
Extending Patio Slab and adding a cover Jeoroc24 Building & Construction 5 04-12-2011 11:16 AM
Insulating an existing floor over a concrete slab rbo Flooring 1 12-06-2010 05:41 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Hardwood glued directly to raidiant-heat slab?? High Desert Man Flooring 3 01-13-2008 05:16 PM
