Floor Dropping - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-25-2013, 08:12 PM   #1
Floor dropping
Hi, recently I noticed that 2 areas on my first floor seem to be dropping, causing the floor to be uneven. Both areas happen to be above old basement windows that have been covered by brick and concrete before I moved in. I live in an old home in South Philadelphia, and have attached a picture of the floor...any insight on what might be causing this, or what I can do to correct it? Thank you in advance for any feedback.
EricDe is offline   Reply With Quote
Old 01-25-2013, 08:41 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 192
Looks like the band or ceil is rotting, or it could be a header rotting if there is or was a window below. You really do need to get under there and check it out, it isn't going to get better on its own.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
DangerMouse (01-25-2013)
Old 01-25-2013, 10:59 PM   #3
747
registered
747's Avatar
Rewards Points: 534
Ya you need to get down in the crawlspace under this with a hammer and start taping. I bet something isn't solid.
747 is offline   Reply With Quote
Old 01-25-2013, 11:04 PM   #4
funfool's Avatar
Rewards Points: 534
Use some clear painters caulk and caulk the gap and problem solved.
funfool is offline   Reply With Quote
Old 01-26-2013, 09:11 AM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 608
Ayuh,.... You need pictures from below, not what you've shown...
Old 01-26-2013, 09:14 AM   #6
AHH, SPANS!!!
Rewards Points: 1,166
could have termites eating the house band, have you called an exterminator? was there quarter round or shoe mold down at one point? looks like it was...
hand drive is offline   Reply With Quote
Old 01-26-2013, 10:22 AM   #7
Rewards Points: 13,296
Could be a lot of things, insect infestation, deck installed right up aginst the siding cause rot, siding not ran past the foundation so water can get in and rot the rim joist, floor joist spliting where they notched them to sit on the rim joist.
