Floor Drain Against Drywall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-28-2011, 07:01 PM   #1
I have a floor drain in my attached garage. Three of the walls of the garage are on footings raised above garage floor, one is sitting right on grade of the garage floor (this wall is non loadbearing). The drywall on this wall touches the concrete floor. The floor drain happens to be installed about an inch away from this wall as this is the lowest point of the garage.
For minor spills, liquid flows right into the drain. However, for larger spills, fluid puddles around the drain as it slowly drains away. Thus soaking the drywall. What is the best way to resolve this?
acerunner is offline   Reply With Quote
Old 09-28-2011, 07:10 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
First thing to do is to cut the drywall upward about 1/2" or more if know there is something more than a 2X4 behind it. Then seal the bottom cut edge of the drywall with a waterproofing. At that point the wall still needs some protect a little higher maybe. You could use liquid waterproofing or you could use ceramic tile, or you could maybe find a quality exterior paint, you could use plastic, you could use sheet metal. There are any number of ways to protect the drywall once the bottom of it is raised and protected.
Old 09-28-2011, 09:12 PM   #3
^^ That advice sounds good
Maybe you could use the metal in a strip as a "baseboard" on that wall and caulk it at the floor? Wouldn't look too terrible
mnliberty is offline   Reply With Quote
Old 09-29-2011, 12:33 PM   #4
Originally Posted by Bud Cline
First thing to do is to cut the drywall upward about 1/2" or more if know there is something more than a 2X4 behind it. Then seal the bottom cut edge of the drywall with a waterproofing. At that point the wall still needs some protect a little higher maybe. You could use liquid waterproofing...
It is pressure treated 2x4 behind there. What kind of waterproofing do I use for the edge of the drywall? what kind if liquid waterproofing for the wall?
Old 09-29-2011, 02:01 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I would first use a quality exterior caulk and seal the opening and finger it upward onto the raw edge of the drywall. Then (after the caulk has skinned-over) a liquid waterproofing such as Redgard can be used to again seal over the caulk and up the wall a ways. Redgard can be purchased at Home Depot and it is found in the ceramic tile department.
Rookie questions - drywall paper rips Eusibius2 Drywall & Plaster 13 08-14-2010 09:46 PM
Basement drywall ceiling and walls questions enero Drywall & Plaster 6 06-05-2010 04:13 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 10:30 AM
Drywall over plaster? Rob1980 Drywall & Plaster 10 04-11-2009 06:05 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 02:12 PM
