Old 07-25-2012, 11:31 AM   #1
Floor decking thickness
I need to deck an area in an unfinished space just so it can be used as storage right now. The joists are 16" O.C. 2x8's. What is the best thickness to use? the whole house right now is decked with OSB, I think its 23/32? is that too much for storage space or not enough? the rest of the house they have 23/32 osb then a 1/4" sheet of ply overtop of that glued and nailed down
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 07-25-2012, 11:56 AM   #2
From my days as a carpenter we always ran 1-1/4" t&g ply for our subfloors. It's more expensive than osb but hold up much better over time.
Ian Rogers is offline   Reply With Quote
Old 07-25-2012, 11:59 AM   #3
That's gotta be pretty heavy huh? I'd be hulling this up a flight of steps
Old 07-25-2012, 01:13 PM   #4
I used 3/4-inch Advantech decking when I built my house. It has a 50-year warranty against water damage.
Old 07-25-2012, 01:33 PM   #5
guess 3/4 would be stronger then 23/32 since its slightly thicker, never saw their stuff though, its resin composit sheets? Any advantages of this over OSB?
Old 07-25-2012, 07:46 PM   #6
GBrackins's Avatar
50-year warranty against water damage ... what does the osb come with????? I always spec out Advantech and most builders I know use it exclusively
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 07-25-2012, 07:53 PM   #7
I will have to remember this if we ever get to building a new house. Is the cost relatively close, or is it greater pricewise?
Old 07-25-2012, 10:04 PM   #8
GBrackins's Avatar
depends on where you are, but pretty much the same
Gary
Old 07-26-2012, 12:59 AM   #9
JOATMON
ddawg16's Avatar
23/32 vs 3/4" (24/32)? Hmmmmm....that works out to 1/32" difference.....
I'm doing a 2-story addition right now....my second floor is 1 1/8" T&G.....I questioned it at first...but now....very glad....about par to walking on concrete.
Don't do OSB....it does not do as well as floor sheathing....OSB is better suited to shear walls.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Need to taper the thickness of a 2x8 - How? laportebj Carpentry 7 09-09-2011 07:59 AM
Plywood thickness: asked for 1/2" plywood; hardware delivered 7/16 (.437) thickness) lazzlazz Flooring 7 03-31-2010 12:25 PM
Dry wall thickness question tripower Building & Construction 14 09-02-2008 01:50 PM
Subfloor thickness?? whiskeykid Flooring 9 08-13-2008 12:06 AM
Correct thickness for brick privacy wall doingygirl Landscaping & Lawn Care 5 05-21-2008 04:49 PM
