-   -   Floor decking thickness (http://www.diychatroom.com/f19/floor-decking-thickness-151484/)
BlueBSH 07-25-2012 10:31 AM
I need to deck an area in an unfinished space just so it can be used as storage right now. The joists are 16" O.C. 2x8's. What is the best thickness to use? the whole house right now is decked with OSB, I think its 23/32? is that too much for storage space or not enough? the rest of the house they have 23/32 osb then a 1/4" sheet of ply overtop of that glued and nailed down
Ian Rogers 07-25-2012 10:56 AM
From my days as a carpenter we always ran 1-1/4" t&g ply for our subfloors. It's more expensive than osb but hold up much better over time.
BlueBSH 07-25-2012 10:59 AM
That's gotta be pretty heavy huh? I'd be hulling this up a flight of steps
md2lgyk 07-25-2012 12:13 PM
I used 3/4-inch Advantech decking when I built my house. It has a 50-year warranty against water damage.
BlueBSH 07-25-2012 12:33 PM
guess 3/4 would be stronger then 23/32 since its slightly thicker, never saw their stuff though, its resin composit sheets? Any advantages of this over OSB?
GBrackins 07-25-2012 06:46 PM
50-year warranty against water damage ... what does the osb come with????? I always spec out Advantech and most builders I know use it exclusively
BlueBSH 07-25-2012 06:53 PM
I will have to remember this if we ever get to building a new house. Is the cost relatively close, or is it greater pricewise?
GBrackins 07-25-2012 09:04 PM
depends on where you are, but pretty much the same
ddawg16 07-25-2012 11:59 PM
23/32 vs 3/4" (24/32)? Hmmmmm....that works out to 1/32" difference.....
I'm doing a 2-story addition right now....my second floor is 1 1/8" T&G.....I questioned it at first...but now....very glad....about par to walking on concrete.
Don't do OSB....it does not do as well as floor sheathing....OSB is better suited to shear walls.
