Floor Covering For Hunting Lodge Floor. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-30-2011, 01:34 PM   #1
Floor covering for hunting lodge floor.
Floor covering for hunting lodge floor. Other then carpet, any ideas for floor covering? At the moment there is the OSB sub floor. Here is the catch; it is not heated all the time.
Hardway is offline   Reply With Quote
Old 12-30-2011, 01:39 PM   #2
MarginallyQualified
Rewards Points: 2,464
Are you planning to install an actual floor over that sub floor...
for this floor covering to then go on top of?
As to your Q: Vinyl sheet and area rugs.
hth
Old 12-30-2011, 02:24 PM   #3
Looking for a flooring to go over the sub floor. Canít use say a laminate floor as it will buckle with out heat (per factory rep). Press and stick tile will pop up if the temp is not maintained above freezing. At this point if we go with wall to wall carpet and put down padding, donít have to put underpayment down. Hard wood flooring has to be in a controlled environment also. I read about a paint that could be painted on the sub floor and it would look like a gym floor. Need something that could be laid down and hold up under the freeze thaw cycle. We have, forced air, electric base board and high efficiency wood stove. Just canít be up there in the winter as much and not feasible to heat it, when no one is there.
Old 12-30-2011, 02:33 PM   #4
Rewards Points: 508
Fieldstone or ungauged slate over Wedi board. Hickory or walnut if you prefer wood.
benjamincall is offline   Reply With Quote
Old 12-30-2011, 03:28 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Here I sit once again just simply "amazed".
XXX
Old 12-30-2011, 05:24 PM   #6
Rewards Points: 508
Hickory and Walnut are supposed to be reasonably stable. Besides, what's wrong with a little rustic gapping in a lodge?
http://www.hursthardwoods.com/categories.php?cat=723
These folks seem to have some experience installing hardwood flooring in unheated cabins and the like:
http://www.theoakfloors.com/faq.html
They mention sealing the underside and the edges.
I don't have the details of the floor system, but my first choice would be the stone.
Old 12-30-2011, 08:22 PM   #7
MarginallyQualified
Need something that could be laid down and hold up...
How long do you expect **anything** to "hold up"?
Old 12-30-2011, 08:28 PM   #8
joed's Avatar
Rewards Points: 12,440
I have press and stick flooring in my cottage. No heat. Temp get to 20 below at least once every year. Never had a tile come up yet after 15 years. Also have regular glued down block tiles(been in the cottage at least 40 years), and sheet linoleum and sheet vinyl. No problems with any of them from lack of heat.
Old 12-30-2011, 08:34 PM   #9
Rewards Points: 13,458
Engineered prefinished hardwood.
Old 12-30-2011, 08:47 PM   #10
Commercial carpet with all weather area rugs over top.
That's just my opinion. But it's free, so take it for what it's worth to you.
1910NE is offline   Reply With Quote
Old 12-31-2011, 12:12 AM   #11
Rewards Points: 1,092
Anything wrong w/ T&G plywood, stained, and a few area rugs (preferably bear)? It's a hunting lodge, after all.
Old 12-31-2011, 08:12 AM   #12
the Musigician
DangerMouse's Avatar
Cork?
DM
Old 12-31-2011, 01:51 PM   #13
Rewards Points: 508
This is what I think of when I hear the word "hunting lodge":
Old 12-31-2011, 03:26 PM   #14
More then one season!
Old 12-31-2011, 03:40 PM   #15
This is our place, how did you get pix?
First Floor Laundry Room Floor Drain install? hammerlane Plumbing 9 10-21-2011 09:12 AM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 07:45 AM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 07:57 PM
