Old 08-29-2012, 12:10 AM   #1
TDO
Floor beam span
I'm finishing my basement and am trying to determine if I can move my column to accommodate a wider living area. I have a LP Gang- lam. Southern pine 2650 Fd - 1.9 E beam 3 1/2" x 11 3/4" x 24'. The floor joists are spanning 22' (and a few 25' due to an outcropping wall) and are 16' oc. Currently the column is approx centerd at 12'. I'd like to move it to 13 1/2' if possible ( this would move the column closer to the 25' joists). Above joists are a living room, bed room and bathroom. We will be hanging drywall on the basement ceiling. Any help/ suggestions would be appreciated.
TDO is offline   Reply With Quote
Old 08-29-2012, 12:26 AM   #2
Floor beam span
Going to have to get an engineer on site to look this one over. Sounds simple enough to move it over but it invlove cutting out the slab, reporing a new footer at a min. It may have an effect on everything from the basement floor to the roof. Just no way to tell over the net.
Your going to need permits for the rest of the work to.
TDO (08-29-2012)
Old 08-29-2012, 12:26 AM   #3
Moderator
Floor beam span
I doubt anyone on here wants the liability for that move....... hire a S.E. for an hour or so, satisfy your H.O.Insurance carrier.
Welcome to the forums!
Gary
Clothes taking longer to dry?
The Following User Says Thank You to Gary in WA For This Useful Post:
TDO (08-29-2012)
Old 08-29-2012, 12:40 AM   #4
TDO
Floor beam span
Thanks, was thinking I'd need a se. Fortunately, or not depending on your view, we're in rural America no permits needed, but I definitely want to get this right - code or no local code. Was wondering if adding a 11 3/4" x 1 3/4" to span the 13' might work. Would still want to check with a se, but wonder what the cost of the added beam would be - this would give me 11 3/4 x 5 1/4" x 13' Anyone know how much these beams run?
Old 08-29-2012, 12:44 AM   #5
Floor beam span
Old 08-29-2012, 01:06 AM   #6
GBrackins's Avatar
Floor beam span
probably anywhere for $5 to $10 a foot, depends on your local market .....
As Gary said, you don't want to have any structural damage to your home from the work you do, insurance companies tend NOT to want to pay for them
Joe is spot on with needing to involve a professional engineer, whether you need a permit or not.
And I'll leave you with this thought, if you post long enough, or go to enough sites you'll find someone that will agree with you thoughts (of course you do not know them, or their level or knowledge or experience) and they will say "Go Ahead! That's what I'd do" WOULD YOU????
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
TDO (08-29-2012)
Old 08-29-2012, 01:22 AM   #7
TDO
Floor beam span
Thanks GB. No question in my mind I need to find an engineer. Not wanting the whole thing ending up around my ears. Was just wondering what the beams cost if I am told by an engineer that is the way to go. You were right, I finally found similar ones at about $6 lin ft. In my area.
Old 08-29-2012, 01:45 AM   #8
GBrackins's Avatar
Floor beam span
TDO,
post back and let us know how you make out. always glad to hear from posters on their end product. let's us know when we're spot on with advice, and when we're not.
good luck!
Gary
How to calculate Joist span table for 3x8's WillSTX Building & Construction 22 03-19-2010 05:41 PM
Center bearing vs. Clear Span floors -- Span Tables WaldenL Building & Construction 1 10-09-2009 01:24 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 01:08 AM
Max span length on 4-2x10 fir beam? gadget463 Building & Construction 4 08-03-2009 06:51 PM
Patio Roof Beam Span slakfu Building & Construction 4 06-03-2009 11:45 PM
