Flood/Drainage Issue On Garage Man Door - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-16-2011, 10:33 PM   #1
Rewards Points: 53
The problem is that the poured concrete patio is on a mild sloped grade from the backyard towards the frontyard. Ok, not uncommon, right? Well the garage is smack right in the middle of that slope and not to mention, the man door to the garage. Problem is, when it rains, pours, or just watering plants, etc it flows right to the door, into the garage. The garage floor is below grade at the door, at grade in the front... where the water flows and exits through the garage door (door for the cars).
I tried hastingly to pour a cement 'dam' if you will a few years ago... it didnt help.
I would love to fix the issue before I tear down the stucco exterior and replace with cement board planking.
I dont which route to go...
- Build up the foundation, lift the door frame header and install the new door @ 80". This would be somewhat of a safety issue because either entering or exiting you would have to lift your feet somewhat higher than you would on any other step. (Keep in mind then I just have flooded water just sitting on the outside of the door.
- Build up the foundation, leave the header where it is and install a shorter height door with frame (probably like a 70" door ouch!) Drainage still an issue.
- I would love to have the door open at grade, with a minor step maybe and resolve the flooding drainage issue. This seems like the most work. But I guess do it right?! Install a drain infront of the door to drain out in the frontyard?
Any input, suggestions, or similar issues. Please acknowledge! My wet garage makes me sad
*update- Rotated photos
Flood/Drainage Issue On Garage Man Door-garage001.jpg   Flood/Drainage Issue On Garage Man Door-garage002.jpg   Flood/Drainage Issue On Garage Man Door-garage003.jpg   Flood/Drainage Issue On Garage Man Door-garage004.jpg   Flood/Drainage Issue On Garage Man Door-garage005.jpg
altc81 is offline   Reply With Quote
Old 04-17-2011, 08:00 AM   #2
kwikfishron's Avatar
Rewards Points: 376
Bust up the patio and re-grade.
You need at least 6” from the top of grade to the bottom of the wall plate.
Post some pictures from the outside showing the whole area.
kwikfishron is online now   Reply With Quote
Old 04-17-2011, 08:19 AM   #3
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Take a concrete saw and cut a channel in front of the door.
Set a drain pipe into it and daylight the pipe so it has positive pitch.
Fill with 3/4" stone.
If you don't like the stone as a finished product, have a grate fabricated.
PS.....looks like the patio has a crack in it anyway........
tcleve4911 is offline   Reply With Quote
Garage Door Repair Tip doortodoor Windows and Doors 0 03-15-2011 08:05 AM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
Old Genie Garage Door Opener cmgith General DIY Discussions 3 11-27-2006 08:53 PM
Garage Door Opener - Noisy on Closing ? quantass Electrical 2 02-13-2006 02:09 PM
