Floating Shelf On Metal Stud Wall Above TV - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-30-2012, 04:34 PM   #1
Floating shelf on metal stud wall above TV
Hey guys,
I have my TV wall mounted on a thin wall (1/2" drywall, 2" deep metal studs) in my condo. Because it was thin and the wall is used to run cable, power, and telephone lines to the condos above I used plywood on outside of the wall to reinforce the brace. With 8 toggle bolts the thing is rock solid.
I want to hang a floating shelf above the TV now to hold the cable box and dvd player. Would you expect there to be any issues hanging the shelf into the studs above the tv? Just looking at a simple lightweight one from IKEA and the electronics probably don't weight any more than 5 lbs.
Thanks for any advice!
DIY_Jon is offline   Reply With Quote
1-2x6 Stud Cut Through on load bearing wall. 2 top plates still in tact. raguy55 Building & Construction 1 03-22-2012 11:45 PM
what is the angled sheet metal in front of my wall registers? aboynamedmoose HVAC 3 01-29-2012 10:39 PM
Remove 20 inch Stud on A Bearing Wall triduong Building & Construction 7 08-03-2010 06:14 AM
Metal Stud framing ? ct73 Remodeling 3 02-06-2010 12:15 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
