Floating/Free-Standing Stairs? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-09-2012, 05:29 PM   #1
Hi all,
I attempted to search to no avail, one post that looked promising (How to construct front porch stairs using concrete block) had no responses, and "floating stairs" leads to more aesthetic articles than what I am attempting to refer to: floating as in a floating deck, not attached to the house.
We've decided against a deck due to the (limited) size of the yard, but my original research led me to believe that when done right, a floating deck is superior to one attached to the house via a ledger board. Is the same true for stairs?
We badly need a set of decent stairs out the back for a 58" total rise. Right now it's something the previous owner or builder hacked together, not attached to the house (just leaning against it) and needless to say both the wife and kids are terrified of it.
I'd like to avoid having to do anything to the house and just build the stairs as a separate structure, unless it's a complete no-go. I am prepared to do it as "right" as it needs to be with no corners cut. Can/should this be done?
Thanks for your time/patience.
DaveInsurgent is offline   Reply With Quote
Old 05-09-2012, 06:14 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
Yes, it can be done, a bit unusual but it can be done. Attaching to the house structure may be the better alternative depending on your , location etc.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 05-09-2012, 06:45 PM   #3
Rewards Points: 616
can you take a pic and post so we can get a better image
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 05:04 PM
Building Code Requirements: Basement Stairs (Quantity) dutchswan0311 Building & Construction 27 09-19-2011 07:13 PM
Help with staining my stairs kimber Flooring 2 12-04-2009 08:45 PM
Strengthening stairs with less support HitLines Remodeling 1 10-30-2009 12:45 AM
Painted the stairs ... . kimber Painting 8 10-07-2009 12:50 PM
