#1 |
Lemme make it
Floating bathroom cabinet
I am interested in building my own bathroom cabinet that floats out from the wall, not touching the ground, nor having any feet. I'm guessing its size is something like 30" tall, 36" wide, and 24" deep. If I am able to tear into the wall to find the studs, isn't it reasonable to think I could brace a cabinet to the studs with the largest angle brackets I can find? This cabinet will support a heavy plywood top which will be tiled, and a sink and faucet, and will probably be crammed full of junk, adding to the weight. Am I just asking for trouble? Or can I construct it with enough overkill reinforcement to support everything. The cabinet can be attached to both the back wall and on one side, as it could be put in the corner. I'm sure that helps considerably. Any advice is much appreciated.
#2 |
It is a feasible project. You might need to fabricate brackets(or have them fabricated) the correct size to handle the loads. I've never seen, "vanity support brackets" in my travels.
Wall cleats will help with the loads. Ron |
#3 |
old guy contractor
Think of it like a wall cabinet in your kitchen
If the cabinet is built properly it's just a matter of finding the studs and attaching the cabinet to the wall with screws.....pretty simple..... You don't need braces and brackets and hardware...just a cabinet that's built to do this. |
#4 |
Lemme make it
Thanks guys. About the cabinet, T, I'll be making it myself, using an old piece of furniture with a few modification. I just felt like all the weight I would be adding to it, and cramming it full of shhhtuff, and with plywood on top, hardibacker, tile, sink, and possibly someone leaning on it slightly while standing at the sink/mirror, etc... it just seemed like a lot of possible weight to be floating. I know I don't have any kitchen cabinet that supports that much weight. And those are usually not as deep. This is more like a base cabinet, really, and I don't know if I've ever seen those float, per se. But why would I let that stop me? Ha! Dat, I will put a cleat on the top edge, but I think I'll also come up with some kind of bracket for attaching to the stud before adding the drywall back on. That would be lower, creating a 'shelf' for the whole thing to sit on. Maybe my father-in-law can make some sort of large T shaped steel plate or something. These are nice, but I don't think I'll shell out $115 for them, unless I can't come up with anything else: http://www.premierwood.com/24-x-29-h...cs.-p38405.htm
I'll go for overkill here so I don't have any regrets later. Fortunately, this project is about a month or two off, so I have time to mull it over. I'll post pics when it happens. Renate |
#5 |
Lemme make it
Correction... sorry, I meant Ron. I had just replied to someone else named 'dat'. It needs to have the previous posts in front of you for reference when you're responding.
Renate |
#6 | |
Floating bathroom cabinetQuote:
"L" shaped brackets bolted to the framing behind the sheetrock and under this furniture might work, but the consequences of failure is a flood. Ron |
#7 | |
| The Following User Says Thank You to jeffrow1 For This Useful Post: | Renate (01-28-2011) |
#8 |
The way most cabinets are built these days, I would NOT just hang it on the wall. Regular base cabinets sit on the floor, and regular wall cabs only stick out 12". I'd make sure there was good backing on the back of the cabinet, and them lag bolt some L brackets to the studs from INSIDE the cabinet. Just make sure they're not in the way of the lav. I'd also do the same to the bottom of the cabinet using inverted L brackets. Better to do it right than RE-do it right!
#9 |
A Little Of Everything
These guys definitely have you on the right track!
I'd suggest building this vanity with a strong inside frame that includes a 1x4 angled from the other edge down to the bottom of the back. I'd also suggest mounting it in the corner, which you mentioned being a possibility. That would certainly add stability. This is definitely doable, provided you build and attach the vanity correctly.
#10 |
Experienced
Just a question, is this being done because of a heat vent under it?
When its all said and done there is usually more said than done To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#11 | |
Lemme make it
Cheers, Renate |
#12 |
Lemme make it
Out of curiosity, what is the expiration of these threads? I may not get around to this floating cabinet for a few weeks. I'm still doing wiring and drywall work, then the bathroom floor will need tile, and then comes the cabinet. I didn't want the thread to vanish before I got into it, in case I needed some more input. I'll be sure to post some pictures eventually.
#13 | |
Ron |
#14 |
Floating bathroom cabinet |
| Display Modes | |
| Wall oven too Wide for Cabinet | victor07 | Carpentry | 8 | 01-03-2011 12:09 AM |
| Bathroom progress - and future plan | Snav | Remodeling | 1 | 03-03-2010 08:50 AM |
| Piping Layout for New Bathroom | structman | Plumbing | 2 | 02-23-2010 06:24 PM |
| Basement bathroom wiring mess. Little help. | trailblazer1229 | Electrical | 15 | 02-16-2010 10:29 AM |
| German Bathroom Cabinet with Lights | jhassall@dornbracht.co.uk | Electrical | 2 | 01-06-2009 01:58 PM |
