Floating Basement Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-31-2008, 08:51 PM   #1
Floating basement question
Hi, I have a floating basement. I am creating arches around the columns so they look good. Can I assume that if the bottom part of the arch is attached only to the foundation square concrete and post and not the floating slab that I do not need to float this column? Photo attached of the concrete square and metal post I am talking about.
Thank you
cobase is offline   Reply With Quote
Old 08-31-2008, 09:25 PM   #2
Registered User
Termite's Avatar
The expansion joints cut around the base of the post in the picture probably aren't representative of the size of the pad footing underneath. More often than not, they're at least 24x24"...or more like 36x36".
But, it is also safe to say that the concrete inside that expansion joint probably won't ever go anywhere at all, even if the rest of the slab heaves up or down. I think you'd be ok building your column tight to the floor if you need/want to.
Old 08-31-2008, 10:24 PM   #3
Thanks for the info. I kind of thought it would be ok but thought I would check first.
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 10:10 AM
Basement Framing - Floating Slab JackOfAllTrades Building & Construction 8 02-05-2008 04:20 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 08:08 AM
