Floating Basement - Level Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-31-2008, 09:27 PM   #1
Floating basement - level concrete
Hi,
I have a floating basement and I am getting ready to finish it. I have some areas a long the concrete lines that are not even. If I rent one of those concrete grinders to smooth it down a little do you think that would be ok? I'm not looking for it to be perfect as I will just be laying down carpet.
Thank you
cobase is offline   Reply With Quote
Old 08-31-2008, 09:59 PM   #2
Registered User
Termite's Avatar
Grinding it down would probably work, albeit laborious! Self leveling cement might be another option, but would also be a bit of work.
Old 08-31-2008, 10:28 PM   #3
mite, this ain't the easiest post to 'read' & try to figure out what in hell he's talkin' about,,, but, seeing as i read it another direction, grinding the ridges between paving passes would be easier,,, self-levelers're kind of tricky the 1st couple times you use 'em.
google up dustless technologies for a shroud if you're grinding & WEAR GOOD DUST PROTECTION !!!
'floating' slab, not basement,,, 'conncrete lines' = paving ridges OR different elevations of the slab on either side of a crack OR joint ? ? ?
doing imperfect work's fine if its your house & you're doing it.
yesitsconcrete is offline   Reply With Quote
Old 09-01-2008, 07:48 AM   #4
Thanks that does help. What about renting. Do they have machines I can rent that are larger then just a small hand held unit? It is my house and I am just not prepared to remove all of the concrete. I have just a couple areas that I need to grind down.
Old 09-01-2008, 09:23 AM   #5
sure there're walk-behind units 1 can rent but 4" or 7"'ll work fine for your job,,, we'd choose the same w/diamond cup wheels,,, matter of fact, tho i don't ordinarily recommend 'em for anything, h/d has shroud'd sawtec (metabo brand) units & wet/dry vacs for rent,,, i suspect any man worth his salt who owns a home would JUMP at the chance to buy TOOLS but renting does have its place
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Very bumpy concrete floor that is not level cgcaudle Flooring 1 08-31-2008 04:04 PM
How to level small patch of cured concrete? RDS General DIY Discussions 11 06-05-2008 12:41 PM
Basement Framing - Floating Slab JackOfAllTrades Building & Construction 8 02-05-2008 03:20 PM
Need help replacing some concrete in my basement. zmurphy Building & Construction 8 01-17-2008 08:10 AM
