Flexwrap With Grade D Building Paper? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-04-2010, 11:19 PM   #1
Flexwrap with grade D building paper?
Can Flexwrap be used with grade D building paper? This is for a house that will be stucco'ed. Flexwrap looks like a great (and easy to use) product for flashing door and window pans, but I assume that since grade D paper contains asphalt, and Flexwrap is butyl based, those 2 products are incompatible. If that's the case, is there any product like Flexwrap that can be used with grade D building paper?
Fred71 is offline   Reply With Quote
Old 06-05-2010, 05:55 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
separate the flex and the paper with a strip of tyvek if your not sure
Tom Struble is offline   Reply With Quote
Old 06-05-2010, 12:58 PM   #3
Registered User
Rewards Points: 526
Tom's correct.
Excellent adhesion performance
Butyl adhesive performs through extreme temperatures
Adheres to most common building materials”---- phone number at the end, must be used with their other weatherization products for the 10 year warranty: http://www2.dupont.com/Tyvek_Weather...20Bulletin.pdf
Or, research other products.
Be safe, Gary
Old 06-06-2010, 04:19 PM   #4
I never thought of putting Tyvek in between... great idea! Looks like DuPont supports the use of Tyvek on top of building paper as well.
Thank you guys!
BTW - I did some research on like products that would not be butyl based (to avoid the chemical incompatibility issue) but did not come across anything like Flexwrap. Maybe I am thinking too much of Flexwrap right now (I haven't used it yet) but I checked videos on Youtube and it looks like a really easy product to use...
Old 06-07-2010, 07:16 PM   #5
wait till you check the pricegreat product really
Old 07-22-2010, 02:42 PM   #6
I recently spoke to Dupont about this issue and while they wanted me to use tyvek, they said that it would be "acceptable" to use flexwrap with asphalt impregnated building paper, but were concerned about the building paper deteriorating.
Here's what they said:
" Our flashing tapes were designed for optimum adhesion to Tyvek® weather resistant barrier products, as well as most common building materials such as OSB sheathing, wood and or steel stud.We have done very limited adhesion studies with conventional asphalt impregnated building papers and have not noted any particular compatibility issues.
However, our experience from field observations indicate that these asphalt papers tend to degrade and break
down over time, which could compromise the integrity of the moisture barrier if our flashing products are adhered
directly to it.
Therefore we would suggest that the flashing materials be adhered directly to the sheathing in most cases rather
than to asphalt building paper."
Now, that said, I cannot seem to find Grade D building paper and every supply house/lumber yard I call seems to have NO clue even as to what it is. They all end up directing me to use tyvek....
I did talk to one guy at Allied building supply that found Jumbo Tex paper from Fortifiber, but he said it was all out on the West coast. I am in Maryland, why has no one heard of Grade D building paper? Fortifiber's distributor for the NE is www.russinlumber.com and they say anyone can order it. Allied said they can get some sent UPS, but didn't seem thrilled.
FYI I am using it under vinyl siding.
mjzraz is offline   Reply With Quote
direct burial/conduit question entering building wombosi Electrical 8 06-01-2009 11:33 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
International building code and permits rforsha Building & Construction 4 08-28-2006 06:35 PM
