Flex HAV Ducting & Firestop? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-23-2008, 08:57 PM   #1
I have a room in my basement in which the HVAC ducting (3 different flexible lines) enters a bedroom into a soffit area. How do I add a "firestop" around where the flexible HVAC vent enters the room into the soffit area? Not sure how to handle this?
interfx is offline   Reply With Quote
Old 03-24-2008, 02:07 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
Is the soffit part of the rated wall/ceiling assembly? Or is the soffit in place INSIDE of the wall you are trying to firestop and strictly in place to conceal the flex duct? Is this a single family residence? Has someone told you that you must firestop the duct penetrations? The only method that I'm aware of for firestopping non metalic flex duct is to transition it to a fire damper and then back to flex after you are through the rated wall. I'm not a residential code expert, but I haven't seen a code requiring fire stop on duct work used in a residence. If someone has seen it, I'd like more info.
Old 03-24-2008, 10:16 PM   #3
Part of the Wall/Ceiling
Suggested by the Inspector (although he wasn't sure, but thought I should it done by HAVC contractor)
Single Family Residence
He also suggested transitioning to a metallic section through the wall back to flex once it is in the soffit.
I was wondering I could just stuff rockwool around it, if that would work enough...
Old 03-25-2008, 07:33 AM   #4
If the soffit is part of the rated wall/ceiling assembly, then the flex duct is not penetrating the fire barrier. Unless I am missing something, where would you put the mineral wool? Can you post a picture? I've still never heard of firestopping ductwork in a single family dwelling.
Bathroom Exhaust Fan Ducting drtpdee HVAC 1 03-03-2008 07:47 PM
Garage Sub-Panel Firestop Mthrboard Electrical 4 12-03-2007 04:50 PM
Water in Furnace Ducting sdoca HVAC 3 09-14-2007 07:54 AM
Connect metal duct to flex? tigerbalm2424 HVAC 3 03-12-2007 03:30 PM
Types of flex duct and support method wingam00 HVAC 1 06-04-2005 02:12 PM
