Old 12-23-2005, 12:15 AM   #1
Lonicera's Avatar
Send a message via Yahoo to Lonicera
Flat or shed roof
I want to build a small (16x24) rustic cabin, and the birdsmouth cut seems to require more experience than I have, but I wonder about drainage, if I install a flat roof. Is there a way to build a shed roof with fasteners, or is there a way to put a slight pitch to a flat roof?
Lonicera is offline   Reply With Quote
Old 12-23-2005, 12:24 AM   #2
Mod / ArchiBuilder
Cole's Avatar
Flat or shed roof
Birdsmouth cuts are not hard at all with some practice.
Cole is offline   Reply With Quote
Old 12-23-2005, 03:56 PM   #3
Contractor
Flat or shed roof
You can easily go to a lean-to type roof, just build one wall higher.
On small projects like yours I manufacture my own trusses and put the crossties flat on the topcap and secure with hurricane tiedowns. If you beef up the crossties, you can floor over parts of them for storage.
I suggest that you pick up a DIY book on garage or home building.
Teetorbilt is offline   Reply With Quote
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
Venting a shed roof with 2/12 slope atulc Roofing 5 08-25-2006 08:28 AM
Flat Roof Replacement Quote Questions rocketmahn Roofing 1 01-02-2006 07:01 PM
Need Help on the Flat Roof and more... MelindaA Roofing 12 12-21-2005 11:12 PM
Where flat roof meets shingled roof bstyer Roofing 1 07-07-2005 09:34 PM
