Flat Roof Construction. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-15-2011, 10:54 PM   #1
gkaro's Avatar
flat roof construction.
Hi all. Building a flat roof -2.5% slope. The plans call for an air space between the insulation and the ply. Question....if I go with spray foam -2 lb...does the air barrier become irrelevant?
Do building codes allow for this compromise ?
Thanks.
G
gkaro is offline   Reply With Quote
Old 12-15-2011, 10:56 PM   #2
Rewards Points: 1,092
I believe that if it is closed cell spray foam, not open, you are correct because it will be an air/vapor barrier. Check on buildingscience.com or greenbuildingadvisor.com
Old 12-15-2011, 11:26 PM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 666
Send a message via Skype™ to AndyGump
Yes, the International Residential Code does allow for some non-vented attic conditions like you are talking about.
I know it is a flat roof, cathedral type ceiling is not an attic area, but the code calls it that.
There are specific conditions that have to met though.
Andy.
AndyGump is online now   Reply With Quote
New Rubber Flat Roof w Ponding Problems Shifter Roofing/Siding 8 10-20-2010 10:58 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Flat roof headache The Barber Roofing/Siding 7 05-17-2008 05:48 PM
Flat Roof Construction- insulation EricC Roofing/Siding 15 12-02-2007 08:49 PM
flat roof leak snikda9 Roofing/Siding 16 01-26-2006 04:25 PM
