-   -   flat roof construction. (http://www.diychatroom.com/f19/flat-roof-construction-126751/)
gkaro 12-15-2011 11:54 PM
Hi all. Building a flat roof -2.5% slope. The plans call for an air space between the insulation and the ply. Question....if I go with spray foam -2 lb...does the air barrier become irrelevant?
Do building codes allow for this compromise ?
Thanks.
G
jklingel 12-15-2011 11:56 PM
I believe that if it is closed cell spray foam, not open, you are correct because it will be an air/vapor barrier. Check on buildingscience.com or greenbuildingadvisor.com
AndyGump 12-16-2011 12:26 AM
Yes, the International Residential Code does allow for some non-vented attic conditions like you are talking about.
I know it is a flat roof, cathedral type ceiling is not an attic area, but the code calls it that.
There are specific conditions that have to met though.
Andy.
