Old 12-13-2011, 08:26 PM   #1
flasking chimney
can i still use my fireplace if the chimney needs reflasking?
macdeb is offline   Reply With Quote
Old 12-13-2011, 08:29 PM   #2
flasking chimney
There is no such word so I'm guessing you mean tuck pointing. If the chimmneys is poor shape someone needs to fix ASAP. Many many homes have been lost from chimmney fires.
Old 12-13-2011, 08:40 PM   #3
"Nail-Bender"
flasking chimney
"macdeb"
If you mean "reflashing" -
you can probably, use your fireplace.
If you have any concerns - find someone in your area, who knows about
chimneys - have them look at it.
Any leaks (water) -
Wood burning?
rossfingal
rossfingal is offline   Reply With Quote
Old 12-13-2011, 08:43 PM   #4
flasking chimney
Good call, I agree you should be able to use it but in the mean time if it's leaking it's going to do nothing but get more expencive to repair if you let it go.
Old 12-14-2011, 05:48 PM   #5
flasking chimney
gee, i thought it meant take a flask up on the roof & hide from the bride thank you for 'splainin' to me
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Old 12-14-2011, 06:59 PM   #6
the Musigician
DangerMouse's Avatar
flasking chimney
Everyone knows Flask is an old app to render dvd to avi or mpg.... sheesh.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Capping my chimney sbmfj General Discussion 9 10-29-2011 11:45 AM
Chimney repair advice needed cbrc5eric Building & Construction 2 04-04-2010 07:32 AM
Concrete block Chimney problems scoggy Building & Construction 0 03-09-2010 08:00 PM
Roof Leak Around Chimney robertr4836 Roofing 3 03-11-2008 12:23 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing 6 03-07-2008 04:12 PM
