Flashing windows/Installing exterior molding
Hello everyone, I’m a new member here…
So,the gf and I bought a house..an old farmhouse in upstate NY
She had some friends of hers replace the siding, they did not do very good job, but that is another discussion altogether…
I had put in vinyl replacement windows in last year…
My question is this…
When they j-channeled around the windows they simply did a terrible job, then they attempted to wrap the windows with aluminum and it’s not good, I don’t think her friends really knew what they were doing…
So now I want to take all the exterior molding/casing off the windows and replace with PVC molding….even the sills as they are all rotted out….
So I have a few questions…
I want to flash around the windows, when they sided, they left the old tarpaper on, and put ¼” foam over it, then the siding…
So, in watching the videos on you tube/and reading discussions on here, this is what I am thinking is the way to do it
Take off exterior molding, take out window, take off sill, put in a sill plate (I was thinking about the suresill product, others just use flashing tape from what I’ve seen), flash the top, sides, bottom of window…
New tar paper/foam if needed…
Install molding, put window back in…
That sound right?
Thanks in advance
Jeff
