Flashing / Siding Transition - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-25-2009, 10:35 AM   #1
Flashing / siding transition
I'm getting the house prepped for vinyl siding and have run into a little problem with regard to my wall profile. Attached is a drawing of my wall profile. Does anyone have any suggestions as to how I would go about transitioning from the bottom course of siding to the 2" insulation. All the Z flashing around here is only 1" stuff or less.
Any suggestions appreciated
SAGENT is offline   Reply With Quote
Old 06-25-2009, 02:45 PM   #2
Rewards Points: 270
when I needed some pan flashing for patio doors (couldn't find anything in the box stores - and never used a brake) I went to a siding contractor in my area and they bent some stock for me - actually didn't cost much. I gave them a simple sketch with dimensions and they did it up right away.
rtoni is offline   Reply With Quote
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 10:08 PM
MW Vinyl windows w/ JChannel + Hardi Board Siding - Proper Flashing? jboeckler Building & Construction 1 09-20-2008 02:55 PM
Flashing a triangular gable prior to cement siding install GARenovator Building & Construction 1 03-11-2008 10:50 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
