Old 08-17-2008, 08:11 PM   #1
Flashing Question
I have two issues on a slight overhang over my front door. Item 1, I believe I'd be better off just removing all the shingles (it's a small area, maybe 4 feet by 15 feet) and reroofing the area. Item 2 I'm not sure what I should do, I'm not sure if the area beneath the brick shows that it's exposed. Any suggestions for both 1 and 2 would be appreciated. Thanks
Having an issue posting the pic. It's in my photos
swr2000 is offline   Reply With Quote
Old 08-17-2008, 08:16 PM   #2
Flashing Question
roof shot
Old 08-17-2008, 09:46 PM   #3
Moderator
Termite's Avatar
Flashing Question
Is there no flashing at the intersection of the brick and the shingles??? There definately needs to be.
Old 08-17-2008, 09:59 PM   #4
Flashing Question
The piece that looks like the flashing is in the middle of the picture. It looks like there isn't any protection above the flashing against the bricks, then there's also the hole over the shingles.
Old 08-17-2008, 10:00 PM   #5
BUILDER / REMODELING CONT
buletbob's Avatar
Flashing Question
It appears that there was an apron flashing installed. and they installed the last row over the top of the flashing. I like to run all my shingles up under the apron tight to the wall. BOB
Flashing for New Construction Replacement Windows in Stucco House BigJimmy Building & Construction 10 11-03-2007 01:48 PM
when to replace a skylight & flashing question CindiChm Roofing 3 10-08-2007 10:18 AM
Open valley flashing question steve1234 Roofing 2 10-01-2007 01:19 PM
Plumbing vent flashing FatAugie Roofing 7 08-24-2007 09:30 PM
Flashing problems Slave Building & Construction 3 11-16-2005 04:56 PM
