Flashing Posts Protruding Thru A Wall Cap - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-16-2010, 12:54 PM   #1
flashing posts protruding thru a wall cap
we are designing/building an exterior (both sides) wall enclosing a exterior deck space with 4x4 wood posts extending 2' above the wall cap to support a pergola - i'm looking for a good solution to flash where the posts come thru the wall cap
byronkw is offline   Reply With Quote
Old 09-16-2010, 01:09 PM   #2
Chicago, IL
Michael Thomas's Avatar
Can you post links to 1) a wide angle view of the (parapet?) walls with the cap penetrations and 2) a close up of a post penetrating a cap?
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
The Following User Says Thank You to Michael Thomas For This Useful Post:
byronkw (09-16-2010)
Old 09-16-2010, 01:36 PM   #3
Clarification
my apologies - i should have made clear that i am just starting contruction and am looking for a solution before i get too far ahead of myself
Old 09-17-2010, 11:25 AM   #4
Chicago, IL
In my experience it is extremely difficult to provide a durably watertight seal at the penetration of a roof membrane or wall cap by any type of wooden structural member, for example because the wood will absorb moisture, it will expand and contract both seasonally and shorter term at a difference rate as surrounding materials, it's difficult to provide a durable sealant bond to a weathering wood surface, and for many other similar reasons.
It other words, this type of penetration is an inherently Bad Idea.
byronkw (09-17-2010)
Old 09-17-2010, 12:51 PM   #5
your comments mirror my own concerns - and the only system i thought might (?) work would be to countersink a flashing into the posts just above the top of the wall. of course that flashing / post intersection would be subject to all of the forces you describe too...
the follow-up question would be what mechanism would you suggest to suspend / support the pergola above the wall? use steel posts thru the cap? mount the posts on the outside of the wall?
Tags
exterior , flashing , post , wall cap
Flashing question where eavestrough meets stucco wall? chadurban Roofing/Siding 3 12-31-2010 05:42 PM
J-Weep / Flashing for exterior cultured stone veneer wall. Spud Building & Construction 18 08-31-2009 09:44 PM
Does this roof to wall flashing look right? jiminvabeach Roofing/Siding 9 01-07-2009 09:20 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Flashing for Brick Wall sandyman720 Roofing/Siding 5 08-08-2007 10:05 AM
