Flashing Material On Top Of Brick Ledge... - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-25-2007, 02:54 AM   #1
MLO
Flashing material on top of brick ledge...
I will be installing a brick wainscoting onto an old 50's foundation with an integrated brick ledge. The original roman bricks used a 90 degr. aluminum flashing from the exterior wall to underneath the bricks on the ledge.
I have been told that a more modern and water-tight flashing technique is to use a product like nervastrol (sp?). Supposedly it is a polypropylene membrane that is flexible and cut with a utility knife.
Can anyone elaborate on this or maybe a brand?
TIA
MLO is offline   Reply With Quote
Old 10-25-2007, 06:23 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Links:
http://store.dunnlum.com/builderwire...33&itemid=2869
http://www.nervastral.com/product1.htm
- Build Well -
Old 10-25-2007, 09:33 AM   #3
TIA
I wouldnt put that on my house. I've opened up a lot of brick walls where similar materials were punctured or the laps were sealed. Masonry trowels like to cut through it. I would stick with a copper laminate product from advanced flashings or similar
ncgrogan is offline   Reply With Quote
Old 10-25-2007, 09:41 AM   #4
It can be used between the mud sill and the foundation. Like Foam sill is standardly used on most new construction homes today.
link: http://store.dunnlum.com/builderwire...33&itemid=2342
In other applications, it should be installed with a protective material placed over it. See the diagrams and description on the previous link I listed:
- Build Well -
Old 10-25-2007, 11:59 AM   #5
I read it, its still junk if you intend to use it as a through wall flashing which is what i thought they meant.
Old 10-25-2007, 03:19 PM   #6
MLO
I'm confused...This is a high end custom Craftsman style home. With-in reason, money for quality details is not a problem. I'm actually using copper valley flashing as everything will either clash with the shingle color or is junk material.
Any masons chiming in?
Old 10-25-2007, 04:21 PM   #7
If you post a picture of the situation, that would help. Do you know if its going to be used as a through wall flashing or not?
Old 10-27-2007, 12:25 AM   #8
MLO
I am severely IT challenged currently. Not sure what "through the wall" flashing is.
The flashing I am referencing is attatched to the bottom of the exterior sheathing/wall and is bent in a 90 degr. angle to also lay on top of the concrete brick ledge. The mortar and brick would be layed on top of it with the apporpiate weep holes. My understanding is that "this" flashing stays beneath everything (mortar, bricks, weeps). Not sure if it is actually bonded to the underlying foundation/brick ledge in any manner.
Old 10-27-2007, 08:35 AM   #9
Yeah thats through wall flashing. The only product I would use is a copper laminate flashing. http://www.advancedflashing.com/comm...pperfabric.cfm Whatever you do, dont let the contractor (if you have one) cheap out on you for any kind of poly material. Its bad stuff in my opinion. I know several Architects that are involved in lawsuits right now for the stuff.
You also need to seal the top of the flashing with a termination bar at 8 inches on center and with flashing mastic. Then either your felt paper or "tyvek" should counter flash it. I dont know what your local code is but the internation building code requires weeps at 33 inches on center.
Old 10-27-2007, 08:45 AM   #10
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Copper through-wall is the only way to go. All these 'new' methods and materials come and GO on a regular basis. Usually with a different name each time.
tinner666 is offline   Reply With Quote
Old 10-31-2007, 11:43 AM   #11
MLO
Well my probable/maybe mason chimed in and recomended a product like Graces "Ice shield". He said it stayed tight to the wall and ledge and was formable with a nice overlap in the corners.
I had never heard this, anyone?
TIA
Old 10-31-2007, 11:53 AM   #12
TIA
Ice and Water Sheild is an excellant product for window wrapping, underlayment,etc. but it is not a through wall flashing. Ask him if he intends to use it as a through wall flashing. If he does the only acceptable materials are copper laminate and stainless steel. You are going to pay more but its worth it. If there is any dust present the ice and water sheild will not stick to the surface well, especially if its not primed.
Old 10-31-2007, 01:17 PM   #13
MLO
For clarification...My brick ledge is the same ledge the pt sill plate is j-bolted to. The foundation stem wall is 9" wide with 5" being used for the brick footing and 1" air-gap.
So my flashing will start on the wall, bend 90 degrees, and run onto the concrete brick ledge.
My intentions were to use Grace Ice-shield around the full perimeter of the home and attach what-ever flashing over the Ice-shield and onto the brick ledge. I would then run "60 minute" paper over the flashing and up the wall.
When describing this to a mason, he replied to just run the Ice shield in a 12" width and forming it into the 90 degree bend and onto the brick ledge.
I very much appreciate the input, Thanks!
Old 10-31-2007, 02:46 PM   #14
Is this what you are describing?
Old 10-31-2007, 03:55 PM   #15
MLO
Yes, that is the flashing I'm refering to. In my case, the bricks and the pt 2x4 sill plate are on the same level/plane. The foundation wall is just simply 9''s instead of being stepped.
Thank you for your patience!
new construction no Brick ledge Justbeck101 Building & Construction 25 11-19-2012 02:03 PM
Counter flashing where roof meets vertical brick wall sandyman720 Roofing/Siding 5 02-20-2011 11:13 AM
Flashing for Brick Wall sandyman720 Roofing/Siding 5 08-08-2007 11:05 AM
Flashing against brick? sandyman720 Roofing/Siding 6 03-22-2007 09:36 PM
