Flashing An Existing Window - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-22-2010, 10:01 AM   #1
Flashing an existing window
Hello,
I am working on vinyl siding my house. I have taken off the old siding, installed foam board and have wrapped the house in Tyvek. My concern is at the windows. Because I windows were installed before I wrapped the house, how do I make sure that the windows are properly sealed to make sure water does not get behind the Tyvek, foam board and on to the sheathing?
Thanks,
EDubes is offline   Reply With Quote
Old 06-22-2010, 12:54 PM   #2
Handyman
Rewards Points: 512
You could fold the Tyvek into the seams and fill the gaps with expanding foam insulation. That stuff sticks to EVERYTHING When its dry, cut the excess with a knife before you install the j-mold and drip cap.
PS: Use the foam sparingly...too much could expand enough to buckle walls and distort window frames.
canadaclub is offline   Reply With Quote
Old 06-22-2010, 03:18 PM   #3
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
Will you have access to the window flanges? If so cover them with a rubber membrane product like Grace vycor.
At the top of the window install a rain cap (using caulk) first and vycor over that.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 06-22-2010, 08:09 PM   #4
When I removed the siding there was no window flange. The windows are replacment windows.
Old 06-22-2010, 08:21 PM   #5
Tom Struble's Avatar
Rewards Points: 2,002
its almost impossible to reflash these windows without removing them and installing a sill flashing,are you wraping the windows with aluminum?in that case you can flange the trim
Tom Struble is offline   Reply With Quote
Old 06-22-2010, 09:43 PM   #6
No, the windows have wood wood. I wasn't going to wrap them in aluminum.
There is a plastic membrane that extends to and attaches to the sheathing between the head/side jams and the window trim. The windows are kind of "flashed" with this? It is under both the foam board and tyvek wrap.
Tags
tyvek , vinyl siding , window flashing
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
proper steps in wrapping tyvek and flashing windows?? 4just1don Building & Construction 4 11-17-2008 06:10 PM
Flashing an existing ledgerboard opssusan Building & Construction 5 02-22-2008 05:48 PM
