Old 08-21-2010, 03:33 PM   #1
Wire Chewer
Red Squirrel's Avatar
Flashing/caulking when adding something to an outside wall
This is more of a general question. I'm just wondering what steps need to be taken to prevent water issues when installing something such as an outside receptacle, a dryer vent, wall AC unit etc... I have a brick house. I assume this is probably trickier then with siding.
I'm thinking of installing a receptacle in front of my garage since the only accessible one to plug my car in winter is inside the garage which makes me have to run an extension cord under the garage door. I would rather just get a shorter cord and be able to plug it right into the garage. I just want to ensure I do this properly so water can't seep in the hole that I have to create. Is it just the thing of stuffing it with mortar?
Old 08-21-2010, 05:11 PM   #2
I have a brick home as well, and when I have changed the dryer vent, added an outside receptacle, or routed my fuel oil lines through the wall, I have simply mortared them in. In the case of the fuel oil fill and vent, I removed one complete brick, routed the lines through, and mortared around them, and painted it a color close to the brick, then, after we switched to propane, I chipped out the mortar, reinstalled the brick, and it looks original again. In the case of receptacles, I have used metal boxes, but rather than tucking the mortar, I finished it flush with the brick, so that when I installed the outdoor cover, the gasket had a flat surface to set against. For small holes, like when I changed the entrance cable and phone line, I punched the hole as close to exact as I could, and sealed it with gray caulk.
Old 08-21-2010, 05:38 PM   #3
Wire Chewer
Ah so guess it's as easy as that then, figured there may have been more to it. Guess it's not as involved as roofing given it's a vertical surface and water has less tendency to stick. Not like I'm building a ship hull or anything.
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
adding wall insulation inside or out? jgreaves General Discussion 1 09-26-2009 06:16 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 04:29 PM
adding interior wall gillispf Building & Construction 2 03-17-2009 07:34 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
