Flashing Around Window With Brick Veneer - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-05-2009, 03:41 PM   #1
flashing around window with brick veneer
My house is on the water in quincy ma, the east winds and rain are to say the least brutal. The brick veneer on the second floor i think is not properly flashed if at all. The windows have to be replaced and i would like to know how they should be flashed before i talk to a contractor. What is the best way to flash an already existing wall and windows? On days with north east winds and rain we get a good amount of water in the kitchen under the windows. I have since put tacky roofers flashing around the outside of the window and the leak has subsided 95%. We need a contractor that knows what to do. Help
Mark Whalen is offline   Reply With Quote
Old 12-05-2009, 03:42 PM   #2
water leak help
Old 12-05-2009, 04:03 PM   #3
concretemasonry's Avatar
Rewards Points: 2,566
If you install new windows, make sure the flashing goes under the above and the adjacent "primary moisture barrier" (Tyvek/tar paper, etc) to make sure the water is shed behind the brick. Probably 2/3 of all windows are installed improperly, but I only see the problems of the 20% that show horrible signs soon.
Dick
concretemasonry is online now   Reply With Quote
Old 12-05-2009, 06:20 PM   #4
Are your windows installed with bucks, do they have trim butting up to the brick? Could you post a few picks? As the previous poster mentioned, they need to be sealed against the drainage plane under the brick.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 12-05-2009, 07:02 PM   #5
if you are replacing windows that are already bricked against you will be hard pressed to flash properly without removing brick. your window supplier should have solutions for a retrofit and using a good grade of commercial sealant at the brick/ window joint will be crucial. brick is very porous and there are times where a long driving soaking rain will get thru to the back. I have had to treat brick with a sealant to eliminate this problem. a good masonry suppiler, not a big box should be able to offer suggestions that are easily applied by a diy'er. you also may be able to add weep holes at the brick lintel above the window to release water and below the window bricksill to do same. hope this helps
Replacement Aluminium Window - Reusing existing sill flashing? GrantJohnson Building & Construction 4 02-10-2010 11:27 AM
J-Weep / Flashing for exterior cultured stone veneer wall. Spud Building & Construction 18 08-31-2009 10:44 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
New opening in a brick veneer wall - installing new brick ties? GrantJohnson Building & Construction 3 01-28-2009 11:17 AM
