Old 08-25-2009, 10:57 PM   #1
Knucklez's Avatar
flare out bottom of deck pier hole?
i dug a hole 8.5" dia 4' straight down using a post hole digger. i want to flare the bottom of the hole to assist in preventing frost jacking. i tried using a garden hoe but i had no leverage at all with which to dig out the sides of the pier hole.
any ideas on how to do this effectively?
Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 08-25-2009, 11:24 PM   #2
Moderator
Termite's Avatar
That's a mighty narrow pier and it'll be hard to get much angle at the bottom. It it were wider a sharpshooter shovel usually does the trick, and you clean out the spoils with the hand posthole digger.
Old 08-25-2009, 11:44 PM   #3
Moderator
If for frost heave prevention, it needs to be wider for the gravel under and around to keep the water from freezing: http://books.google.com/books?id=1gg...num=3#PPA31,M1 Plastic wrapped, footings attached, etc.
http://rockproducts.com/mag/rock_agg...prevent_frost/
http://www.sustland.umn.edu/implemen..._footings.html
I gave you three, because I know how you like to read....
And some added protection: http://www.oikos.com/esb/43/foundations.html
Be safe, G
Old 08-26-2009, 05:26 PM   #4
Knucklez's Avatar
OK, i hear you. "don't be lazy, dig a bigger hole."
Old 08-26-2009, 07:14 PM   #5
Old School
Willie T's Avatar
GBR, you always come up with some of the most interesting reading!
Willie T
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
Building a Deck - Questions about pouring the footers Ler0y Jenkins General Discussion 5 06-03-2008 08:42 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
