Flagstone Patio Vs. Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-19-2008, 11:32 AM   #1
Question
Flagstone patio vs. Foundation
We took out a concrete pad against our house and replaced with a large flagstone patio (mortared, not sand base).
There is a definite slope away from the house, so we're good there.
I can see that there was flashing behind the siding and between the foundation and concrete pad. Can someone tell me if this is suggested (required) with the new patio?
Relative told me just to fill in the space with mortar...
Any suggestions?
Cangirl is offline   Reply With Quote
Old 06-19-2008, 01:14 PM   #2
Registered User
Termite's Avatar
Can I assume that your siding is very close to the level of the patio? That would account for the flashing at the siding in some cases.
There is normally a gap of some sort between a concrete pad and a home's foundation. This is essentially an expansion joint. Your house is on footings deep beneath the surface, so it is reasonably immune to heaving in frost and sinking due to settlement of the soil. The pad, on the other hand, sits on disturbed earth and is subject to movement due to settlement and frost heave. Therefore, the gap allows the slab to float, separate of the foundation.
If your house has been there for several years, you could probably put mortar or flexible sealant in that joint with no problems at all. I'd opt for something flexible.
Hopefully there is a sand or gravel base under your flagstone patio??? If they're set directly on the dirt it wasn't built for longevity.
Old 06-19-2008, 05:42 PM   #3
The concrete pad, where the existing flashing was originally installed, was close, yes.
So the flashing was there in case that slab moved... got it.
Now that there is an average 1/2 inch gap between foundation and flagstone, and about 3" from flagstone to siding, can we forgo the flashing?
House was built 10 months ago. Are you guessing something will move? We were going to fill in the gap between the foundation and flagstone with mortar, just to prevent debris, leaves from accumulating. Not good?
At least 4" of 3/4 minus base, and our flagstone suppliers, "the pros," don't seem to think we get the kind of frost heave in the Pacific NW that will create problems a gravel base can't handle.
Thanks for your help!
slumped patio fix ?? houser Building & Construction 5 03-18-2010 06:25 AM
Flagstone patio help sixeightnick Landscaping & Lawn Care 1 06-11-2008 10:40 AM
Flagstone patio sedwick Landscaping & Lawn Care 6 04-16-2008 04:18 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 08:11 AM
Flagstone Patio cpbraun Flooring 4 11-21-2006 03:43 PM
