Fixing Water Damaged Carport Support - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-30-2010, 11:43 AM   #1
fixing water damaged carport support
i have some water damaged 4x4 support posts in my carport, I was wondering what was the best way to fix them. I do not want to remove them, maybe just cut them off and put something underneath to keep them out of the water.
withered is offline   Reply With Quote
Old 10-30-2010, 11:49 AM   #2
Rewards Points: 212
A picture would really help if you want some detailed info.
orange is offline   Reply With Quote
Old 10-30-2010, 04:42 PM   #3
Rewards Points: 5,336
It depends on how high up the damage goes. If it's only an inch you can use a Simpson post hardware piece. But you need to drill in under the post to secure it to the slab.
Ron
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
Well Water snuggles2010 Plumbing 3 04-13-2010 02:36 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Water damaged basement subfloor chhamilton Flooring 6 02-14-2008 03:06 PM
