Fixing Up A Steel Framed House - Header Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-03-2009, 02:11 AM   #1
Fixing up a Steel Framed house - Header Question
Hi All,
Live in a small town, just bought a fixer-upper and discovered it is steel frame construction. I am very handy and would like to add a window to an existing exterior wall. Do I need to use steel headers or can I put in wood header?
JThomie is offline   Reply With Quote
Old 04-03-2009, 06:57 AM   #2
Remodeling Contractor
If you are referring to steel studs you will use wood for the jack studs and wood for the header.
Old 04-03-2009, 07:18 AM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
+ 1 (agreed).
- Build Well -
Old 04-03-2009, 09:48 AM   #4
Rewards Points: 392
It can also be done with metal.
rustyjames is offline   Reply With Quote
Old 04-03-2009, 10:00 AM   #5
Not really. How doe you attach the trim and even the door or window?
Old 04-03-2009, 10:57 AM   #6
Steel Studs
Thanks, will give it a go incorporating a wood header.
Old 04-03-2009, 12:12 PM   #7
Rewards Points: 392
There's self-drilling trim screws. It's done every day in commercial construction.
Question about steel I BEAM in basement djohns10 Building & Construction 7 06-23-2012 03:55 PM
Ground Clamps Question integlikewhoa Electrical 40 02-28-2008 09:13 PM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
Question about repainting house outside randalg Painting 3 07-21-2006 04:10 PM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 02:57 PM
