Fixing Rotten 4x4 On Exterior Stairs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-06-2011, 02:59 PM   #1
Fixing Rotten 4x4 on exterior stairs
Hey Everyone...
I have a two story flight of exterior stairs where the majority of my 4x4 posts are rotting away at the footings.
I have come up with a solution that I think will work that doesn't require taking out the post entirely (which really isn't possible) or splicing in a new piece.
The plan will be to remove the existing blocks the post are sitting on, cut out the dry rot portion of the post, dig new footings and fill with concrete.
The one thing that needs to happen is that the new footing will need to be extended upwards to make up for the dry rot that was cut off... so my question is how high can I extend an 8" column (using a sonotube form) above the ground.
(Proposed Detail)
Mironov Central Home Renovation Blog:
www.mironovcentral.blogspot.com
atmironov is offline   Reply With Quote
Old 04-06-2011, 03:46 PM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
When you look at coastal homes on piers.....
and bridge piers....
and just decks in general.....
I'd say you can go up as high as you need ( 1-2') to as long as you design it properly.
You may want to include some rebar if it gets too high.
tcleve4911 is offline   Reply With Quote
Old 04-06-2011, 04:30 PM   #3
General Contractor
SeattleSurfaces's Avatar
I'd check your local codes on footing sizes. I bet you need to go bigger than 8", particularly if you are extending above ground any distance at all.
A regular pier block has a foot print larger than 8" and that is the smallest footing you can use locally and never for anything near the size of what you are looking at supporting.
Good luck.
SeattleSurfaces is offline   Reply With Quote
Old 04-06-2011, 04:50 PM   #4
Old School
Willie T's Avatar
I have set hundreds of 8" to 10", sometimes larger, tubes for second story motel walkway columns. Needless to say the size and rebar were specified by engineers.
http://www.sonotube.com/products/son...sizechart.aspx
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
SeattleSurfaces (04-07-2011)
Old 04-06-2011, 05:01 PM   #5
concretemasonry's Avatar
Rewards Points: 2,626
The area under the footing will be determined by the load on the post and the strength (capacity) of the soil.
The depth of the concrete depends on the code minimums or frost depth.
Use a Simpson bracket attached to the concrete (before or after pouring) that eliminates concrete contact with the wood.
Do not put concrete around the base of the wood post since it retains moisture that can be absorbed by the wood eventually and stops drying out.
Dick
concretemasonry is online now   Reply With Quote
Old 04-06-2011, 05:05 PM   #6
From the website...
"Builder's tubes are designed for below-grade use, but may be poured to three feet above the ground line. They are not designed to be stripped. No bracing is needed unless used two feet above ground line. Even then, bracing requirements are minimal."
Help! How do I fix rotten wood under door? glamgirrl Building & Construction 24 10-06-2014 10:07 AM
Rotten bathroom subfloor tallycat77 Flooring 14 02-08-2013 09:59 AM
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 08:08 PM
Help - rotten exterior wall support studs Charbl General DIY Discussions 2 11-15-2010 06:27 AM
Rotten Wood janet.hampton Carpentry 1 07-04-2010 02:22 PM
