Fixing Previously Botched Finish Plaster Over Scratch Coat - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-31-2012, 09:02 PM   #1
fixing previously botched finish plaster over scratch coat
Evening all, thnks for your time & expertice.
Plastered house, 1948, built by father in law, was very skilled & adept.
No upkeep from family till too late.
Purchased & am fixing.
Roof leaked & moisture damage caused some of the finish plaster to separate from the scratch coat (still well bonded to the 2x8 panels).
Was "repaired" with regular easy sand spackle.
question:
Bathroom, removed wall paper, found fixes from water damage. Crap spackle will soften to clay with spray bottle. Don't believe I can remove it well enough to adhere plaster to scratch coat even with bonder.
What can be used to solidify the spackle? So I can Skim coat it.
Water soluable Polyurethane? Shellac may not be good in a bathroom.
How does the PVA bonders stick to it?
Scratch coat is good & solid.
Please any ideas.
Thnks
todd
twd1 is offline   Reply With Quote
Old 01-31-2012, 09:13 PM   #2
Rewards Points: 14,000
Did you not say for some reason you were spraying water on it trying to remove it. Just stop spaying and let it dry.
If your trying to seal water stains on old plaster I would use an oil based primer then go over it with latex paint.
Old 01-31-2012, 09:29 PM   #3
more info
Spray wall paper remover was used.
Existing fix was spackle in corner.
The rest of the non bonded finish coat was ignored.
I removed loose finish coat. Now I need to skim with finish coat.
Looking to seal spackle so that finish coat will bond.
anyone run into bathroom fixes that hold up? concerned on humidity.
will be installing an inline exhaust to the room
thanks all
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 06:23 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 05:27 AM
Mudding Finish Is Showing on Final Coat Hages Painting 7 03-19-2007 10:09 PM
finish coat over painted walls a_theater_god Remodeling 2 07-30-2006 10:27 PM
I'm going to end up with a seam of greenboard meeting plaster, how should I finish? J187 Building & Construction 2 06-06-2006 07:53 AM
